My next Road Race Project: ASA Monte Carlo to Camaro conversion
Over the winter I picked up an ex Michael Waltrip Racing ASA AC Delco Monte Carlo. The car was raced by the grandson of Mr. Butler of Aaron's. One of the Aaron's "Dream Machines". It is the Howe type chassis as used in V8 StockCar GTA and Trans Am 2. It has a good, strong Lingenfelter LS1.
It will get a total ground up rebuild and have the following:
* strong Lingenfelter ASA spec LS1
* fresh quartermaster 7.25 triple disc clutch
* fresh road race Jerico 4 speed
* freshened Winters quickchange rear
* new Bassett lightweight inertia steel wheels
* six piston Wilwood calipers on front
* new 4 piston Wilwood Superlite 3's on rear
* Kirkey road race set
* new interior sheet metal
* new Howe Trans Am 2 Camaro body
At around 2500 # without driver or ballast and with 400 plus HP to the wheels she will be one quick ride.
We will probably race her a few times and then offer for sale. Will be very affordable, probably in the the range of a used T1 C5 Corvette.
Maybe somebody in the south will buy her and come race with us in Crane Cams V8 StockCar.
Would love to see detailed pictures of the build as you go along. I bought a left hander chassis and Monte Carlo body along with various other goodies from Gregg Rodgers a couple months ago for a song. Figured it would be my project for the next couple of years. I would to be able to put a Camaro body on this so I will eagerly watch you do your magic.
Jay
Jay
Will post pics as we move along, also in the middle of the road race late model build. It got stalled for a while, but is now rolling with the motor in the car. It will be a nice piece as well with Penske's, big cup Brembo's, the Trans Am 2 front clip and suspension.
The Corvette is running again after a couple of motor issues, broken LS7 lifter and later the guts falling out of a stock rocker. Now has the Comp Cams trunion upgrade.
Shouldn't require shortening the wheelbase on this. We did shorten our first Camaro a bit, only because that then made it unneccessary to cut any bars. The flat black car went from about 105 to 102.
