abs/ active handling control issue ?
we have upgraded our c6 to a full track car.. Big Brembos, Motons coilover, Pfadt sway bars, ccw on slicks, full cage and so on.. yesterday we test at Homestead Speedway and the abs, traction control gave me all kind of problem with the bigger front brakes and .. we ended pulling the fuse and the car performed well ..
the question i have is,,, will the pulling of the fuse affect the power/Maps settings in the ecm.. ?
any info would really help...
Received 8,929 Likes
The EBCM controls the ABS, TC and AH. Pulling the fuse on it will not do anything to the ECM except set a diagnostic code in it indicating it lost communication with the EBCM.
Bill
Bill
Matt
Bill
I would be interested to know more about the bias (from the ebcm) with and without the abs fuse. What I meant by 50/50 bias was the fluid line pressure applied to the front and rear calipers. Not the actual braking force applied to the rotors which of course is dependent upon piston area. I always thought less line pressure is applied to the rear with the abs system functioning but I'm not sure. If the bias doesn't change with the fuse pulled compared to heavy braking with the abs fuse (non-lock up), I would be much more willing to pull the fuse. My abs/active handling drives me crazy in my T1 car. I think I have it narrowed down to one of the power steering sensors/circuits.
In my C5Z with the fuse pulled, I have found the bias to be spot on using Hawk HT 10s all around. I initially started using a less aggressive pad in the rear, but since have not found it necessary.
