Coolers on a c6 car being used 60% for track days
Guys need some suggestions I have a 2007 c6 with the ls2 tuned, headers, cats, z06 brakes, track suspension, oil coolers, power steering cooler, brake coolers, baffles in oil pan. I can run with z06 and gt3 no problem. My issue is rear diff over heating and concerned with transmissions i am running oversized tires 275/35/18 up front 305/35/18 in the rear . Anyone know of an economical solution for coolers on the diff and trans. I stopped running slicks until I can figure out a solution. They seem ok on the r888 for the short term.
Trans and Diff coolers from DRM (Doug Rippe Motorsports) at $650 each. I needed both, but you can try the diff alone first. I am very pleased with them. You need a modicum of fabrication skills to install them. I used 3/4" x 1/8" steel plate from the hardware store to fabricate the mounts needed. I ran fused wires from the fuse box down each rocker panel to the pumps.
There isn't anything cheaper that works - you must get the hot fluid out of the case. I tried insulating my pipes with exhaust tape and various Redline fluids - didn't cure the awful noise that my diff began making when hot, nor did it stop the trans overheat warning.
Now I can run hard continuosly in 95F heat until the tank runs dry without any overheating.
DIY man!
Grab a few pumps, Some fittings, 10-12' of AN line, and some coolers and PRESTO! for 500-800 you could have some serious cooling on your track car.
Used NASCAR parts are also an extremely good value.
CI 3-5-6-7-8 Veteran
What do the tires have to do with anything? I've been racing my car for 2 years now w/o a trans or diff cooler. Yes I need a trans cooler, but I don't see how running different tires will affect things? FWIW I run Amsoil synthetic ATF in the trans and Amsoil Severe Gear 75w110 in the diff.
