Brake Cooling Parts
Old 07-11-2012, 09:27 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default Brake Cooling Parts
Brake Cooling Parts
Keep your brake rotors and calipers cool with our brake cooling parts. We have many options available for you.
3" Compact Inline Blower, 5" Long, 140 CFM
Works great install inline in the stock front splitter opening
$28.99
Durable plastic brake ducts direct outside air for cooling brakes, oil coolers ... even the driver, and are available in centered, offset and dual outlet configurations.
Dim 5.5" x 8"
This fits perfectly behind the front grille no cutting of the grille some modification to the inner grille required for mounting
$18.99
http://www.xplosiveperformance.com/B...nt_p_3054.html
Brake Duct - Offset Single
Dim 5" x 9.75"
Works great if you want to remove the fog lights fits with minor modification
$21.99
http://www.xplosiveperformance.com/B...le_p_3055.html
Size:  14.7 KBName:  ALL42151.jpg
Brake Duct Hose, 3" x 10', Orange, 550 degrees
Hose is designed to direct air from front mounted air ducts to spindle ducts for brake cooling. Flexible, non kinking hose is available in three temperature ranges. Sold in 10 ft. lengths. 275 degree - 3" single ply thermoplastic rubber wall with a spring steel wire support. 300 degree - 3" or 4" double ply neoprene coated woven fiberglass hose with a spring steel wire inner and an external fiberglass cord support. Smooth inner wall for unrestricted flow. 550 degree - 3" or 4" double ply silicon coated woven fiberglass hose with a spring steel wire inner and an external fiberglass cord support. Smooth inner wall for unrestricted flow.
3" Brake Duct Hose Flange
Flange rivets to nosepiece. 3" diameter brake duct hose can then be hose clamped to flange.
$28.99
Old 07-13-2012, 07:20 AM
Former Vendor
St. Jude Donor '13
Brake Cooling Parts
Old 07-14-2012, 12:37 PM
Former Vendor
St. Jude Donor '13
$28.99
http://www.xplosiveperformance.com/3...FM_p_3052.html
Old 07-14-2012, 04:11 PM
y5e06
y5e06's Avatar
i'm interested in these pieces, are they aluminum or steel? they look like galvanized steel.
$28.99
Old 07-14-2012, 04:55 PM
Former Vendor
St. Jude Donor '13
They are Aluminum sorry will put that in the description.
Old 07-15-2012, 06:27 PM
Former Vendor
St. Jude Donor '13
$28.99
http://www.xplosiveperformance.com/3...ge_p_3059.html
Old 07-17-2012, 05:13 PM
Former Vendor
St. Jude Donor '13
Brake Cooling Parts
$28.99
Dim 5.5" x 8"
This fits perfectly behind the font grille no cutting of the grille some modification to the inner grille required for mounting
$18.99
Dim 5" x 9.75"
$21.99
$116.99
other size hoses available
http://www.xplosiveperformance.com/B...es_p_3053.html
$28.99
Old 07-21-2012, 05:50 PM
Former Vendor
St. Jude Donor '13
$28.99
Old 07-30-2012, 03:08 PM
Former Vendor
St. Jude Donor '13
Brake Cooling Parts
$28.99
Dim 5.5" x 8"
$18.99
Dim 5" x 9.75"
$21.99
$116.99
$28.99
Old 08-10-2012, 09:24 AM
Former Vendor
St. Jude Donor '13
Brake Cooling Parts
$28.99
Dim 5.5" x 8"
$18.99
Dim 5" x 9.75"
$21.99
$116.99
$28.99
Old 08-15-2012, 10:36 AM
Former Vendor
St. Jude Donor '13
Brake Cooling Parts
$28.99
Dim 5.5" x 8"
$18.99
Dim 5" x 9.75"
$21.99
$28.99
Old 08-17-2012, 07:02 PM
Former Vendor
St. Jude Donor '13
Brake Cooling Parts
$28.99
Dim 5.5" x 8"
$18.99
Dim 5" x 9.75"
$21.99
$116.99
$28.99
WE ALSO HAVE SPINDLE MOUNTS
Old 08-22-2012, 05:17 AM
Former Vendor
St. Jude Donor '13
Brake Cooling Parts
$28.99
Dim 5.5" x 8"
$18.99
Dim 5" x 9.75"
$21.99
$116.99
$28.99
Old 08-27-2012, 05:53 PM
Former Vendor
St. Jude Donor '13
Brake Cooling Parts
$28.99
Dim 5.5" x 8"
$18.99
Dim 5" x 9.75"
$21.99
$116.99
$28.99
Old 09-12-2012, 01:47 PM
Former Vendor
St. Jude Donor '13
Brake Cooling Parts
$28.99
Dim 5.5" x 8"
$18.99
Dim 5" x 9.75"
$21.99
$116.99
$28.99
Old 10-09-2012, 02:01 PM
Former Vendor
St. Jude Donor '13
Brake Cooling Parts
$28.99
Dim 5.5" x 8"
$18.99
Dim 5" x 9.75"
$21.99
$28.99
SPINDLE COOLING DUCTS ALSO AVAILABLE
Old 10-09-2012, 05:54 PM
sean.b
sean.b's Avatar
why does your URL list this for a Scion??..
Old 10-10-2012, 07:43 AM
Former Vendor
St. Jude Donor '13
These are universal parts and can fit and work on any car.
To Brake Cooling Parts
Quick Reply: Brake Cooling Parts
