How to drain Oil from an ARE oil Pan?
Old 07-21-2012, 07:58 PM
Searya
Searya's Avatar
Default How to drain Oil from an ARE oil Pan?
I have an ARE 1007 Dry sump oil pan with a stock oil tank. I am trying to change the oil and have removed 2 plugs from the pan (one draining straight down and one horizontal). So far with the initial gush all I have gotten out about 2 quarts of oil. Anyone know what I am doing wrong?
There is still a slow oil drip coming out of the plugs but doubt it will amount to the extra 7 quarts.
Thanks for your help!
Old 07-21-2012, 08:46 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
Take the lines to the pan off!
Jim
Old 07-29-2012, 08:25 PM
JVetthead
JVetthead's Avatar
I dont know about the stock tank, but I have to suck the oil out of the ARE tank not the pan. This is a NON stock setup tho..
To How to drain Oil from an ARE oil Pan?
Quick Reply: How to drain Oil from an ARE oil Pan?
