Retrofit DRY SUMP OIL SYSTEM ENHANCEMENTS Kits for 2006-present Corvette Z06
Former Vendor
St. Jude Donor '13
BOLT-IN DRY SUMP OIL SYSTEM ENHANCEMENTS FOR THE LS7
Retrofit Kits for 2006-present Corvette Z06 and other applications using LS7 engines!
100% compatible with OEM components
Provides oil control the factory left unfinished
Retain use of factory air conditioning, power steering, alternator, oil filter, oil cooler, oil tank and all plumbing
Helps prevent oil from being vented into intake
Easily installed —welding required 1 fitting in tank
Improves engine reliability and performance
To bring the Z06’s lubrication system to competition caliber, Aviaid has designed a compact single-stage pump that, incombination with the OEM scavenge pump, more than doubles the stock scavenge capacity, as well as enhances the evacuation of crankcase pressure and ensures that once oil accumulates on the floor of the pan it is removed efficiently.The pump attaches to the passenger side cylinder head and is driven by a timing belt. An adjustable Katech idler assembly featuring a custom combination drive pulley replaces the stock spring-loaded idler and pulley assembly. It is driven by the factory serpentine belt and subsequently drives the pump. The kit includes an auxiliary pickup for scavenging, while a companion pickup replaces the OEM unit. To feed the pump an AN –10 line is routed from the oil pan to the pump. An included weld-in tank bung provides the connection point for the auxiliary scavenge pump return. Other than drilling a hole into the pan for the pickup bung, drilling a hole and welding a fitting in the tank, and running two lines from the pan to the pump and sump tank, no additional fabrication is required. And the most important thing to remember is that everything has been designed to work in concert with the OEM air conditioner, powersteering, alternator, etc. What’s more, it does not require relocating the oil filter, or replacing/modifying any oil tank or oil cooler lines. It’s asstraight forward and clean an installation as you’ll find anywhere.
Includes:
LS7 OEM Tank Insert
LS7 OEM Pan Pickup Trap Assembly w/ doors and Trap Windage Tray
Section Scavenge pump w/ 45D outlet port -10 x-10
LS-A Oil Pump Adapter Plate
Bolt Kit LS-A Pump Installation
3.5” Tensioner Serpentine Pulley w/ 14T Gilmer Pulley
Katech LS Fixed Adjustable Belt Tensioner
Locking Collar 5/8 x 1”
LS7 Pickup OEM Replacement 60
LS7 Pickup Auxiliary Pump
Belt 225L050 (Gilmer)
Pulley 5X04 46 G
LS7 OEM Tank Insert
Pulley 5X04 46 G
$1548.36
Former Vendor
St. Jude Donor '13
Includes:
LS7 OEM Tank Insert
Pulley 5X04 46 G
LS7 OEM Tank Insert
Pulley 5X04 46 G
$1548.36
Former Vendor
St. Jude Donor '13
Includes:
LS7 OEM Tank Insert
Pulley 5X04 46 G
LS7 OEM Tank Insert
Pulley 5X04 46 G
$1548.36
Former Vendor
St. Jude Donor '13
[QUOTE=PA Z06;1581528907]Has anyone tried this yet[/QUOTE.
We run this system on our own ZO6 and it is great if you do any racing and high g Corning or on any high bank tracks its only a matter of time. We run Senring Miami Homestead Road Atlanta and others and we haven't lost an engine to oiling problem yet
Former Vendor
St. Jude Donor '13
Includes:
LS7 OEM Tank Insert
Pulley 5X04 46 G
LS7 OEM Tank Insert
Pulley 5X04 46 G
$1548.36
Picture of how it looks installed on our car
