TPMS Cannister Info
TPMS Cannister Info
As many of you know, you cannot fully disable tc/ah in a C6 if you are below 25psi, and its a pain to mess with it on track. To get the ideal hot temps on many of the tires we run, you need to be below that mark.
After fighting the stock TPMS system for a couple of years, and having it lock the front right caliper and pull me off the track, I decided to do something different.
The first effort was to send the BCM to WAMS and have them delete the system; this worked for a couple of other forum members but I had a horrible experience with them. The BCM didn't work, and after a month of no response, I was told to bug off.
https://www.corvetteforum.com/autocrossing-and-roadracing/2980292-tpms-delete-beware.html
I remembered reading a few threads on the pressurized cannister to fool the TPMS system, and decided to send a few PM's and get details. The response wasn't what I was looking for - more "it should work" than "this is how I did it". It seemed like more people were going to do it than had actually done it.
Well, it works...but there are a few things you need to know.
1. I made the cannister from 4" PVC and a valve stem. After letting the 3rd cannister dry overnight and having the cap pop after adding 30 psi (I am a former pipe fitter, so I know how to make the joint properly), I decided to use hose clamps in addition to and immediately after gluing the joints - one on each cap, and one long ways around the entire cannister. This will keep everything together when the car gets hot in the summer.
2. Be patient. After getting everything together and knowing the cannister was holding pressure, the DIC read 0 psi. I went for a drive, did a few brake checks to rattle the sensors and just when I thought it wasn't going to work the car picked up the signal.
3. On the track you are moving the sensors enough for them to send almost constant signal. With everyday use, especially hwy driving, you need to do an occasional hard brake check or an aggressive turn occasionally to keep them talking. If not, they will lose signal.
I will post pics later today, but overall I'm very happy with it. It's nice to be able to finally have control of the system.
Because the TPMS don't fit very well in 2" screw pipe, and the valve stem doesn't like the wall and cap radius.
You can get much bigger than 2" diameter, I've got a piece of 4" here that I use as a die for bending sheet metal. That strap idea is pretty slick, but as you probably know, that PVC is gonna turn into a grenade if it fails, especially if it gets real cold or dries out.
Did you just put them in the container loose, or pack something with them to keep them from rattling around?
Approx how tight did you make the hose clamps around the caps? Guesstimated torque value?
Did you consider a removable cap on one end?
Certainly glueing them is easier and faster.
Thanks for the pics, they explain a lot.
I put the sensors in loose so they would rattle around - the more they rattle, the more they broadcast. The hose clamps are approx 100 inch lbs.
Nice, thanks (for when I get c6z). If they need to "move" more to broadcast, how about if you suspended them somehow, thinking bungee, so that average car movement is amplified by the suspension?
Certainly no point in keeping it simple if you can over complicate it.
I did this in 2005 and it has been posted a couple of times on the forum. I have put air in it precisely one time and it is still working just fine. I also wrapped the sensors in a thin foam sheet so they do not "bang around".
You just need to cut the tube to gain access. To do over again I would use one cap and a sewer clean-out on the other end.
Other details: I mounted a tire valve meant for mag wheels so it screws on and had rubber grommets. I mounted it in the center of the cap so that I can put the whole setup in a drill chuck and spin it to wake the stupid things up. Ridiculous isn't this? Oh yeah, never ever ever use the rubber plugs that you screw and they expand.. they don't hold, nope, uh uh, don't do it, don't even try it!
With no TPMS sensors registered and reading safe pressures, you are not able to enter into Competitive Driving Mode, or better yet, get past that mode and be able to turn all the nannies off altogether (TPMS is required for Competitive or Nannies off mode). The car stays in Active Handling mode which applies the rear brakes and can send you off track.
The only mod I would make to mine (if I were to do it again) is to use a clean-out plug on one end so it does not need to be cut apart to open. It will seal just fine .... or you chit will leak out!
"Maybe" correct; however, since each sensor has a unique address I am not sure they can not be re-programed even if they are together.
