New hubs for C5 Corvette
I think it is time to replace the hubs on the C5 race car. I am not the best "wrench turner" in the world, is this a project that an average person can do?
Very easy up front, a little more involved in back, but still easy.
If you have the stock fasteners, you need the weird T55 Plus size bit, IIRC (though double check).
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Go SKF, John. Your aero is now making it a little more tough on 'em. Winning TT's costs, you know. Give me a holler if you want me to talk you through it.
Just did this job a couple days ago.
The only difficult part(s) were:
Getting the axle nut off/on -lots of torque.
Man handling the axle and ball joints into place.
Needing unusual tools like the large torx and a 33mm socket.
Dog
Dog
There are a few how-tos of this in the tech forum. Regarding the rear lower bj bolts, I think it is significantly easier to remove the upper bj nut so that you can tighten the lower bj nut, install the axle, then tighten the top bj nut. Otherwise you need to fool around with a cut allen key to tighten the lower bj (there is very little clearance btw the halfshaft and the lower bj) - which is a pain and you might strip the threads. Removing and then fastening the upper bj nut adds a minimal amount of time (5min?), though you will need a bj popper (NOT a pickle fork).
Former Vendor
The installation is pretty straight forward. I would also suggest going with the SKF set up. Please feel free to call, email or PM me anytime with questions.
Kind regards,
Jordan Priestley
888.308.6007
Kind regards,
Jordan Priestley
888.308.6007
