August And Sept 2012 Tow Hooks, SKF Hubs, Delrin Bushings and More..
Supporting Vendor
Good Morning everyone.
If anyone wants to get their 2012 car prep done, maintenenace updated or just needs some parts, don't hesitate to call or email...
Mark, Kurt O Kurt Rezzetana are ready to prep your Corvette and get it ready for the track!!!
Below is the updated list for setup work, tow Hooks, SKF Hubs, Delrin suspension bushings and some other items that are new, like Brake ducts and adjustable end links......
Call 610-482-0141 if you have any questions or to order with CC info. I try to answer all the calls myself, but if I am on the phone, you will get my voice mail. Just leave a message and I will call back as soon as I can. If you would like pictures of any of the items below, send an email to jfaphoenix32@aol.com and I will email pictures. I prefer emails or phone calls..
We also have pictures on www.phoenixperformance.net under parts and cars for sale. Please note though that the on line ordering feature is not operational.
Thank you for your business and support. We appreciate the kind words of all of our friends and customers.. If you ever want to discuss Corvettes, ST, T1 and track day issues, don't hesitate to call. If you want to do something more advanced, like a World Challenge car, or a Rolex GT car or STO car, just call me.
Prices below already refect 10% discount off of our normal prices.
Joe
1. C5 Tow Hooks Hinged front and rear...... $145 Per Set, Frt and rear. We do sell these separate, $85 for front and $75 for rear.
2. C6 Tow hooks are sold separately, non hinged rear only $145... Front Screw in for c6 corvettes $165
Or, buy them as a pair for $265. See #3 below.
3. C6 Z06, C6 Z51 and base model, Removable front Tow eye and non hinged Rear Tow hook set $265
4. Roll cages for C5 and C6 Corvettes, Z51, Z06 and ZR1, call for info and prices. All of our cages are custom built to your specs.
5. C6 and C5 Corvette Track Day Set up and Other maintenance. Call for Information. 610-482-0141. We will customize the setup to your specs or we will use our own.
6. Engine rebuild service. Complete balance and blueprinting, machine shop, cam and head upgrdes and performance improvements. we install Ktech cams and internal parts on request.
7. C5 and C6 engine tuning by appointment.
8. Supercharger and turbo Installs. Authorized Hennessey Performance Installer.. Call for quotes and specific specs.
9. Complete Set of Delrin suspension bushings. For all control arms. Get rid of the rubber bushings that push out for good!!! $1195 per set for the bushings, including install. (send us your control arms) plus shipping...
10. Transmission and differential installs. We recommend Rockland units and do the installs. Clutches, pressure plates, Half shaft and driveshaft and torque tube work also.
11. Electrical and hard to solve problems our specialty.
12. SKF HD wheel bearings/hubs. $350 per hub. ARP studs extra.
13. C6 Z06 Takeout suspension and interior parts. See list under c6 parts
14. C5 and C6 Track day cars for sale. See listings under c6 and c5 cars for sale.
15. Penske shocks
16. Brembo brakes
17. Hawk Brake pads
18, Cobra Racing Seats
19. Shroth Racing seat belts
20. Phoenix Adjustable endlinks 149 per set of 2.
21. Phoenix 3.5 inch aluminum brake ducts $595 for front pair.
Joe
15. Penske shocks
16. Brembo brakes
17. Hawk Brake pads
Hi Joe,
I wanted to thank you for taking the time to give me the teck tip, you were correct that it was a ground issue. I had lost the bolt that goes thru ground strap and one of the harness grounds to the block above the oil filter....
Replaced the bolt and no more DIC codes and the fuel pump relay works normally.
can't wait to get the SKF bearings and the tow hooks installed this week to be ready for the Glen.... hopefully I wont need the hooks unlike last week when I needed them and did not have them.
Thanks again
Bob Cairns
Thanks again
Bob Cairns
I'm looking on your site and don't see any info on item #21, the brake ducts.
Do you have any pics of the setup? I'm looking for a front cooling setup for a C5Z.
