Can anyone confirm spring kit 12499224 are the same as LS6 "yellows"?
CI 3-5-6-7-8 Veteran
Ordered two sets of "LS6" springs PN 12499224. One for my Z06 and the other for the LS1 crate motor I'm putting in my father's Panoz. I was surprised to see they're darker blue just like my old 2001 Z06 springs. I even compared them to some of the old springs I took off my car and they look identical. I was expecting a really bright royal blue as per Geerookie's pictures. Did I get something incorrect, or has GM gone back to making them darker blue?
Thanks,
Brian
EDIT
Looks like the new springs are indeed more blue than the old 2001, they just don't look quite as blue as the ones Greg got so my mind was playing tricks on me. Also they pop under my garage lights vs. when I first opened the box inside.
Left to right - '99 LS1 spring, 2001 LS6 spring, LS2/3 "new" spring
http://sphotos-b.xx.fbcdn.net/hphoto...13219838_n.jpg
'99 LS1 spring
Shape - Round
Width - 0.182"
Height - 0.182"
2001 LS6 spring
Shape - Oval
Width - 0.202"
Height - 0.162"
New LS2/LS3 spring
Shape - Oval
Width - 0.214"
Height - 0.172"
Clearly these springs are beefier than the 2001 Z06 springs. It's easy to see just from looking at the pictures. When I get around to pulling my heads for the lifter swap in a couple of weeks I'll make sure to compare the yellows I'm replacing.
Thanks,
Brian
EDIT
'99 LS1 spring
Shape - Round
Width - 0.182"
Height - 0.182"
2001 LS6 spring
Shape - Oval
Width - 0.202"
Height - 0.162"
New LS2/LS3 spring
Shape - Oval
Width - 0.214"
Height - 0.172"
Greg's post pretty much confirms it, but the springs I got don't look bright blue like this...
They look just like my old 2001 Z06 springs...
Here's the current part number from the GMPP Catalog and a picture of the springs.
12499224 LS valve Spring kit
• Beehive style springs
• Used on LS2/LS6 cylinder heads
• 1.800" installed height @ 90 lbs. pressure
• Max lift .570"
• 1.250" @ 295 lbs. pressure
• Includes 16 of P/N 12586484
• Max lift .570"
Yellows are no longer available, only blue. I have never seen a cracked blue one, but I am concerned that the blue ones are slightly smaller in wire diameter than the yellow ones, which more than likely means slightly less seat and open pressures...
I'll check the wire diameter vs. the yellows I'm taking off my car for the normal preventative maintenance spring swap. However, the stuff I've read says the specs are the same as the yellows, but that could just be bad info. It wouldn't surprise me that GM just went back to the older/softer blues when they introduced the LS2 which was the '01 LS6 cam/heads on a 6.0 motor and then just stuck with them. What makes me curious is how Greg's picture shows super bright pretty blue springs, but the brand new sets I got look old/faded/dark like the original ones I pictured in my first post.
• Max lift .570"
• Max lift .570"
Yeah it looks like these have replaced "yellows"... at least on Scoggin-Dicky's website. I'm curious if they're the same specs as the "yellows". From what I remember the '02-'04 springs were slightly stiffer than the 2001 springs, but that could have simply been forum hearsay.
Thanks for measuring... you motivated me to do some research and pretty much answer my own question. Only thing I don't have is a spare "yellow" spring to measure as they're all in my engine still.
'99 LS1 spring
Shape - Round
Width - 0.182"
Height - 0.182"
2001 LS6 spring
Shape - Oval
Width - 0.202"
Height - 0.162"
New LS2/LS3 spring
Shape - Oval
Width - 0.214"
Height - 0.172"
'99 LS1 spring
Shape - Round
Width - 0.182"
Height - 0.182"
2001 LS6 spring
Shape - Oval
Width - 0.202"
Height - 0.162"
New LS2/LS3 spring
Shape - Oval
Width - 0.214"
Height - 0.172"
