Any tricks to fix a leaking PS pump?
Old 08-21-2012, 08:46 PM
taken19
Track Junky
taken19's Avatar
Default Any tricks to fix a leaking PS pump?
Or do I need to break down and buy the Turn 1 pump? If so, what is the part number for a 2005 C6 Z51?
A little background... 11tn track day on the car, 2nd day on Hoosiers. Noticed small leak in the PS pump, looks like its coming from the shaft seal. I hear this is not uncommon and I thought I read that some of you have devised a way to buy more time. Please share your secrets if you know any. If not, I guess a new Turn 1 pump may be in my future.
Thanks for any info,
Sean
Old 08-21-2012, 09:03 PM
rustyguns
rustyguns's Avatar
Sean
50/50 mixture of redline power steering fluid and Lucas power steering fluid. flush the old crap out first
but turn one is nice
Old 08-21-2012, 11:33 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Flush the entire rack and pump with a good grade synthetic or you can try the mixture above. Start saving your $ as a Turn One Pump should be on your "Next Thing I Gotta Do" List. I would also use their billett pulley. It makes installation very easy with the cut outs in the pulley, besides you are probably going to break the old plastic pulley taking it off anyway.
Old 08-22-2012, 04:10 AM
taken19
Track Junky
taken19's Avatar
Thanks for the suggestions. I have heard very good things about the Turn 1 pump, but wanna see if I can save my stock one first. I will give the Lucas/redline fluid a try.
Old 08-22-2012, 06:27 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I had a small leak in my p/s unit also. I added some Lucas Stop Leak - not sure of the exact name of the stuff - leak fixed. Hope it works for you also.
Old 08-22-2012, 01:06 PM
taken19
Track Junky
taken19's Avatar
Thanks Bill. I used some during the flush to RP with the intent on having some of it stick to the seals. Maybe didn't sit in there long enough do do anything - only in for a dozen turns of the steering wheel or so then slowly pushed out. I guess I will swap to redline/Lucas mix and add a bit of the stop leak.
To Any tricks to fix a leaking PS pump?
Quick Reply: Any tricks to fix a leaking PS pump?
