DIY Car Elevated Stand
Old 08-21-2012, 09:46 PM
victorf
victorf's Avatar
Default DIY Car Elevated Stand
delete this post
Old 08-22-2012, 12:30 AM
froggy47
froggy47's Avatar
Old 08-22-2012, 12:14 PM
Bad Karma
Bad Karma's Avatar
Nice. I like this idea! I may have to build something myself...
I would consider leaving the welds alone for structural strength over grinding them down, just prep and paint.
Old 08-22-2012, 04:07 PM
dbratten
Support Corvetteforum!
dbratten's Avatar
DIY to me is closer to this
but good job if you have the tools and skills and time.
Old 08-23-2012, 09:47 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I don't get it... why not just use jack stands on the chassis like everyone else?
1. Jack front crossmember.
2. Lower front cradle onto stands.
3. Jack rear cross member.
4. Lower rear cradle onto stands.
Done... no ramps, no fancy fab'd stands, and you can work on the car with the wheels/tires off.
Old 08-23-2012, 10:13 AM
waddisme
waddisme's Avatar
Those would come in handy for like adj preload when installing front sways. I had to borrow some ramps so I could get at mine. I have some 6 ton jackstands I use if I need car up that high for extended projects. Nice diy project though.
Old 08-23-2012, 10:15 AM
Cobra4B
Cobra4B's Avatar
I have two sets of rhino ramps for doing stuff where I need the suspension loaded. Not knocking the fabrication, it's a good idea if you have the metal and time to DIY.
Old 06-30-2014, 02:37 PM
victorf
victorf's Avatar
Elevated Stands in action, confirmed its worth to myself based on the initial idea:
Just my way to skin a cat!
Certainly not agreeable to everyone, right?
To DIY Car Elevated Stand
Quick Reply: DIY Car Elevated Stand
