Stop Tech 2006- 2011 Chevrolet Corvette (Z06; GS) - Red 6-Piston Caliper 2pc Rotor
Old 08-22-2012, 05:23 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default Stop Tech 2006- 2011 Chevrolet Corvette (Z06; GS) - Red 6-Piston Caliper 2pc Rotor
2006- 2011 Chevrolet Corvette (Z06; GS) - Red 6-Piston Caliper 2pc Rotor: 355 x 32mm
Big Brake Kit 2pc Rotor
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
StopTech’s® Balanced Brake Upgrade system is Engineered to directly replace the stock system, providing the correct brake torque output using the vehicle’s original master cylinder and no additional proportioning adjustment. Each StopTech® big brake kit includes forged 2-piece aluminum calipers with our patented bolt-in bridges, AeroRotor® two-piece brake discs with aluminum hats, StopTech® street performance brake pads, caliper adapter brackets, DOT-compliant stainless steel brake lines, and all hardware requiRed for a complete installation.
Before ordering a StopTech® big brake kit, make sure you print out our wheel fitment template to determine if the StopTech calipers will fit behind your existing wheels without interference.
$3195.00
delivered lower US
PM
or Call Toll Free
888.493.8041
for Corvette Forum Pricing
Save
Quick Reply: Stop Tech 2006- 2011 Chevrolet Corvette (Z06; GS) - Red 6-Piston Caliper 2pc Rotor
