Driveway Alignments
Old 08-29-2012, 06:58 AM
larryfs
larryfs's Avatar
Default Driveway Alignments
I see many alignment tools on ebay.... for the DIY-er. Anyone try any of them ?
Old 08-29-2012, 07:34 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
https://dl.dropbox.com/u/1634366/align.pdf
You probably already have all you need. The key is practice and CONSISTENT measurements
Old 08-29-2012, 08:19 AM
larryfs
larryfs's Avatar
http://www.ebay.com/itm/221114916898...=p5197.c0.m619
I was considering the above.
Old 08-29-2012, 08:58 AM
MongoZ06
MongoZ06's Avatar
I have the Longacre Digital Camber/Castor gauge and like it a lot, it's really easy to use for getting the measurements and making adjustments.
Also have an Allstar toe gauge, this one I really don't care for.... it has too much play in it to get accurate measurements. When I have time I'm going to use the string method for checking toe and thrust angle.
I do repair work as a secondary business so it made better sense to get the tools to cover a wide range of cars. I would honestly try Mr. Farmer's method first to get the car set how you want, if you're planning on making adjustments down the road multiple times then it may make sense to consider buying the tools just to make the process a little quicker.
You can find a multitude of web pages showing how to make turn-plates to save you some money.
Old 09-14-2012, 08:49 PM
TEXHAWK0
TEXHAWK0's Avatar
http://www.ebay.com/itm/180943818905...84.m1497.l2649
This toe in gauge is good for the price.
However, if you do not have much fender clearance, you will need another set of pointers that are straight, or only bent slightly closer to the tip...
To Driveway Alignments
Quick Reply: Driveway Alignments
