What ABS sensors on SKF hubs?
Old 09-11-2012, 04:51 AM
NEWs
NEWs's Avatar
Default What ABS sensors on SKF hubs?
Hello fellow board members.
We are looking into adapting a abs system into our race car.
In that process wešll need to get new bearings/hubs as the ones we have now are missing the abs sensors.
The ABS supplier needs to know what sensor is used on the SKF hubs,
We hope they are using one of these two: TLE 4941 or TLE 4942-1
Would anyone here know what type is used on the hubs?
In advance thanks!
Brgds
Nils
Old 09-11-2012, 10:18 AM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
I dunno - but I know who does!!!
Take a look at post# 3 in this thread:
http://forums.corvetteforum.com/c6-t...or-output.html
If that isn't enough info, contact brgguy (bearing guy!!). His name is Ken and he works for SKF, so he can tell you everything you need to know!!!
Bob
Old 09-11-2012, 10:27 AM
vette6aut0x
vette6aut0x's Avatar
What abs system are you going to use?
Old 09-11-2012, 11:22 AM
NEWs
NEWs's Avatar
We are now looking at the bosch motorsports system.
Brgds
Old 09-11-2012, 12:03 PM
0Louis @ LG Motorsports
Former Vendor
Louis @ LG Motorsports's Avatar
Youll need the ZR1 SKF, as the Bosch ABS requires an Active sensor.
Its the same hub, but larger axle spline, and active sensor, and yellow pigtail.
Old 09-11-2012, 12:07 PM
Former Vendor
Basically, it goes like this-
SKF Built the new hubs, everyone loved them. They were made for small axle spline, and passive sensor.
When GM built the ZR1, they wanted to use that hub, however, the bosch ABS they used required the active sensor, and they also stipulated the larger axle spline.
When SKF built them, they would only build that hub with the active sensor, for GM.
So, if you have an early model car, you can get the SKF Hubs anywhere. If you have a new model, active sensor equipped car, you need to purchase them from a GM dealer, and upgrade your axles.
The bosch Race ABS requires an active sensor
Old 09-11-2012, 02:23 PM
NEWs
NEWs's Avatar
Thanks Louis:-)
What the guys at bosch said is that they can make it work with the passive sensor as well, and from what you then say i could eventually reuse my shafts as well.
If not ill have to get new bearings all around, and new driveshafts, so i then would have the active sensor.
But what id love to know is if the part numbers i had in the first post is the part numbers on the abs sensor itself??
Brgds
Nils
Old 09-11-2012, 03:53 PM
geerookie
geerookie's Avatar
I went out to the shop and pulled a new one out of the box.
These are the passive version.
On the hub assembly the stamped part number is SKF BAR 5049C
There's a number stamped below which is KOR 1E 014F
On the sensor itself the numbers are
2478
XE-BAR-5039
Don't see any of the numbers you listed above but these might cross somehow.
To What ABS sensors on SKF hubs?
Quick Reply: What ABS sensors on SKF hubs?
