Carbotech Pads on ZR1?
CF members ...
I wanted to see if any of you have run Carbotech pads (XP10/12) on your ZR1's for the track. I have roasted my stock pads and need to replace and have used Carbotech's on my other track cars. However, with the carbon ceramic rotors ... I am a little hesitant.
Any advise will be much appreciated!
Thanks!
Stephanie
Thanks!
Stephanie
I'd call Carbotech directly-- they're always incredibly helpful.
FWIW, I believe that they typically don't recommend that their pads be used on rotors that have been used with other compounds-- and something tells me you don't want to buy a spare set of ZR1 rotors.
Thanks for your reply! I did call Dan at Carbotech ... love those guys! As for running steel rotor's ... I agree that option would be cheaper, but wouldn't I loose break quality? Hmmm. With my C5Z, I ran XP8/10 with Nappa disposables. Worked great!
Supporting Vendor
CF members ...
Thanks!
Stephanie
Thanks!
Stephanie
I don't know for sure 100%, but I am 95% sure if you run non-carbon ceramic specific pads on your carbon ceramic rotors, you will TRASH the rotors resulting in $4k+ replacement.
Received 3,805 Likes
"Ask Tadge" Producer
Stephanie, I'm going to repeat what I told you in your same ZR1-section thread: stick with the OEM pads. For the ZR1 specifically, there's nothing better out there.
jas
