Mantic Twin
Old 09-12-2012, 10:04 PM
Z06phile
Z06phile's Avatar
Default Mantic Twin
Got this from ECS the other day. It's about 16lbs lighter than the previous setup. I'm happy to see this and I can't wait to try it out.
Mantic Twin:
Mantic steel flywheel:
Ram Powergrip HD:
Ram billet steel flywheel:
Old 09-12-2012, 10:08 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
What are those aluminum blocks for?
Old 09-13-2012, 01:58 AM
heypal
heypal's Avatar
Glad I wasn't the only one confused
Old 09-13-2012, 07:14 AM
rithsleeper
rithsleeper's Avatar
They are weight adders to help the car have a lower center of gravity. You glue them in random spots all over your car like the rims, half shafts, drive shafts, and even throw them in your oil pan for really low mounted weight.
They work well in conjunction with your headlight fluid. Make sure you change your air in your tires from sumer to winter air soon.... This has been a psa from rithsleeper, you're welcome.
Old 09-13-2012, 07:53 AM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes on 656 Posts
Or they are the centering blocks for the discs, I could be wrong though.
Thanks for the business, if you have any questions feel free to call or PM!
Old 12-13-2012, 11:56 AM
Z06phile
Z06phile's Avatar
Sorry for the late update. I've put 100 miles on it and everything is working fine. No hard use yet just trying to break the new clutch in per Mantic and ECS's recommendation. The ECS remote bleeder is much longer than the LAPD one and that's a good thing. Pedal is easy. Not stock easy, but about right in the middle between stock and the RAM Power HD and SPEC 3+.
Here's video of it revving:
http://youtu.be/a3WwrI6N4Q0
Old 04-10-2013, 11:20 AM
DOUG @ ECS
DOUG @ ECS's Avatar
We are now also stocking unsprung discs for race applications and the 7000 series triple for our dedicated road racers.
To Mantic Twin
Quick Reply: Mantic Twin
