Towing questions NJ
Towing questions NJ
I am pretty certain I am going to pick up a Trailex 8045.
I have a few questions. It is 8.5 feet wide. It looks like NJ only allows 8 feet. Curious whether anyone has had issues with this.
http://www.readybrake.com/state_laws.html#NJ
Tow vehicle is a Nissan Armada. What brand/type of load equalizing hitch do you recommend?
The vehicle is prewied for an electric brake controller. Which controller is recommended?
The vehicle has a 7 pin connector. Will that control lights and the electric bakes or should I be looking for other wiring?
I think that the 8' limit may only apply to State roads. Federal highways within the state, should allow 8'.6" wide trailers. You should be okay on all of the interstates, except maybe the Garden State Parkway and the Atlantic City Expressway?
I can't imagine it really would be a problem, on any roads in the State though. I've lived my whole life in NJ, and owned many trailers over the years, and never even thought about how wide any of them were.
Personally, I always buy trucks with the factory hitch, but if I was adding one to a vehicle, I think the only choice would be Reese Draw-Tite.
I have been using the same Tekonsha brake controller, for 12 or 13 years. I've had it in 4 different trucks, and it's worked great.
The 7 pin connector is pretty much standard, for trailers with electric brakes.
I have the P2 and works just fine. The P3 has several "trailer" memory settings you can save along with a couple other features. I don't see a need for them. I adjust my controller each time I pull my trailers. I have a 18 foot open trailer that I haul different cars on as well as a fairly heavy tractor. I also have a 28 foot enclosed trailer. My point being that I would not use the memory feature of the P3 anyway.
Thanks. I just spoke to the Trailex people and they said that I can't (and don't need), a weight distribution hitch on this trailer.
With this said, they also suggested that I consider the surge brakes as it may be a bit more simple, and give greater flexibility. The truck is already wired for a controller. Opinions?
So I will need a ball hitch, brake controller (maybe), Safety chains (recommendations please).
Anything else to get this trailer home?
Thanks for being patient.
No load leveling hitch needed for sure... I use one on my 28 foot enclosed trailer but not the open trailer. My open trailer is steel not aluminum like the one your getting so the gross weight of your setup will be even less than mine. Typically the trailer will come with safety chains. Just get a Reese hitch and ball of the appropriate size to fit your receiver and trailer tongue. The hitch will come in several flavors of "drop" depending on the truck height.
If you are buying from a dealer they will simply outfit your vehicle with everything you need, at a cost of course.
DO NOT GET SURGE BRAKES!!! surge brakes require the tow vehicle to provide the stopping power to actuate the surge brakes. I other words, if in wet weather the tow vehicle starts to slide, the trailer brakes do not actuate!!! You want electric brakes with a controller. I can't believe Trailex would recommend surge brakes on a car trailer. Boat trailers use them because electric brakes do not do well when being put in water on a continuous basis. How ever even the boat trailer industry is starting to us electric brakes more than before. JD
Maybe misunderstood them.
So this is where I am at:
7,121 8045EB
616 tire rack
362 aluminum wheels
271 aluminum spare
50 spare mount
8,420
(750) show credit
7,670
Not a cheap proposition, but at 900 lbs I can push it on the side of the house with some help. Not allowed to keep it on the driveway. It should pull easily behind the armada. It will be 1.5 feet to close to the property line, but I will plant bushes around it, probably not use the tire rack for a while to keep it low and cover it with a cammo tarp.
Hoping for the best. If interested, keep an eye out in the for sale section if the neighbors give me a hard time. I will then be looking for a featherlight or Trailex enclosed to strain the Armada and keep in a public storage lot.
7,121 8045EB
616 tire rack
362 aluminum wheels
271 aluminum spare
50 spare mount
8,420
(750) show credit
7,670
7,121 8045EB
616 tire rack
362 aluminum wheels
271 aluminum spare
50 spare mount
8,420
(750) show credit
7,670
7,121 8045EB
616 tire rack
362 aluminum wheels
271 aluminum spare
50 spare mount
8,420
(750) show credit
7,670
I think you have a good plan there Dom and we'll keep our fingers crossed for ya that the neighbors don't throw a fit. If they do... well let Val and me know, might be an easy sale.
Trailex said they would give me a few passes to get into Carlisle. I am shooting for oct 6 to pick up the trailer there. I will probably go alone so let me know if you are interested in a pass.
I am still open to suggestions if you can point me to one.
Dom,
Sounds like you have a plan - except for the spiders!! I live right in Carlisle and will be at the show at least part of all 4 days so keep me in mind if you get to the show or you need anything .
Mike
Mike
