C5Z DRM Transmission Cooler
When you install a DRM transmission cooler on a C5Z how do you relocate the transmission temperature sender? Or do you??
I'd be interested in anything else somebody has to say about this install too.
Former Vendor
There is a Tee fitting in the kit.
Male end goes into the transmission.
One female end the sensor goes into
The other female gets the straight adapter fitting to -8. Then the straight AN hose end fitting.
Randy
Randy
I just completed a DRM transmission cooler install and detailed it in this thread.
http://forums.corvetteforum.com/auto...ful-hints.html
This should answer just about any questions that you might have on the install. The stock temp sensor is installed in a T fitting in the existing fill hole on the transmission case. Recommend the product, just fisnished my first event since the install and it worked as advertised. Ran the snot out of the car and no tranny overheating.
Hee Hee
Ask a question and you get a response from the manufacturer and a complete how to write up complete with great pictures. (Which I printed out) It doesn't get any better than this. Thanks guys
Last C5
Last C5
