Help....I have to double pump my brakes..
I have a 2011 GS
CARBOTECH xp20/XP10 PADS
Castrol SRF fluid
steel brake lines
cooling ducts
Ran the morning without issues..)TODAY)
Started the afternoon and started to get fade in the pedal early in the session....Stopped and bleed the lines...
Next session....still the same problem....if I tap the brakes before the brake zone then they are firm. It doesn't happen at every brake zone...it seems to need a tap before the brake zones after longer straights..
I know it is not the fluid boiling....
I did put a new set of rotors on the front but it was doing this before I switch them( due to a few cracks in them.)
I read about this problem awhile bad on the forum but unsure how to solve it...
Is this problem in the calipers?
Please help
Tom
Castrol SRF fluid
steel brake lines
cooling ducts
Please help
Tom
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
I replaced bearings with SKF.
Are you running the titanium heat shields between the caliper pots and the stock style padlets? If so, ditch the heat shields until you get some one piece pads. Padlets and heat shields don't mix well when the padlets wear unevenly (first hand experience here).
Received 8,928 Likes
Bill
Supporting Vendor
Knockback is more noticeable after an S section.
The rotor is on the other side of the bearing from the caliper. Bearing tolerance or hub bending will take the rotor with it and bat the pistons back into the caliper. You then have to pump a bit to get the pistons back out.
Many race calipers have a light pressure spring behind the pistons to do this for you.
I have the heat shields..but I also run the one piece pads...XP20's
Supporting Vendor
St. Jude Donor '11,'13
Do not run heat shields.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
