Is control arm bushing repl a diy?
I have 6 weeks until my next track day (work and anniversary commitments). Here is what my left front ca bushing looks like:
I did VIR last Friday with it and it was virtually unchanged afterwards. I am thinking now is a good time to change as I have one track day left in Nov (VIR or RD ATL) and a 2 day at Daytona in Dec. I found bags $10 Home Depot install set up, so will that work to remove? I think I have access to a press but not sure how big. Also, is the Pfadt poly the only real option for 12 days/yr hpde car? So will I need to do all at once or just fronts now and rears over the winter? Would it be better to just take off and ship to someone and have them do them? I am not really comfortable shaving ca diameters or trimming bushings. Thanks in advance for help.
I changed them on my C4 was it was pretty easy. I used my vice and still do not have a press. I have had bushings a bit to long before and just trim them by holding them on the belt sander. The flat side of the bench grinder wheel also works well.
I agree, you can do it yourself if you are reasonable proficient with tools and can read instructions. The worst part is getting the old bushing out of the A arm. You can always remove The A arms and take to a local shop that has a press and have the shop push the bushings out. There have been several recent threads on various methods to remove the bushings.
Take the rear bushing out and flip it over and put it in from the front pointing toward the back. A press is the easiest way.
Put it back on the car.
Reallign it
Done
It's a very time consuming job - especially if you've never done it before.
I have a set of arms (off the car) that already have Pfadt poly bushings installed. I'll swap for yours plus cash if you're interested.
I always say this on this topic, so I will say it again, my mom installed Pfadt polys on my prior set of control arms a few years ago. I cut some of the bushings in half and yanked the dog bone bushings out (on a vice). She did the rest.
Track Junky
As others have said it's not too bad, just time consuming. Plan on spending the better part of a day on this. I needed machine shop help on two of the bushings (on the rear LCA's I think) since I have the most basic tools. Used a vise to install new ones.
Thanks.
The easiest way to get the old bushings out, is to cut off the end with a serrated knife. Then push them straight out with a vise. And the easiest way to install the new ones is with a 12" 5/8" threded rod and some nuts and washers. As shown in one the threads on the forum. Once I use these methods, it took less than an hour to do all of them. JD
The Pfadt kit includes several blocks with varying offsets that allow some adjustment. Of all the vendor supplied camber kits, I think the Pfadt one is the best.
get the cheap press from harbor freight fro $120 it is worth it's weight in gold!!
i did my 1st set in a garage with no power and only a vice mounted on a 6x6 piece of wood and a torch, that was a fun mess!
thankfully my 2nd set i did for a friend was alot easier in my house with full power and good tools
After calling my Mom yesterday (it was her birthday) and even though she can't come help, I think I am going to give it a shot. Do I need to do all at once or just do them as they need it?,
Also, do I really need the camber blocks? I track my car in advanced hpde 2 days a month and dd drive the rest of the time. I may pm David Farmer as he does my alignment.
http://www.youtube.com/watch?v=j3K94lODO00&feature=plcp
Already watched . Definitely getting the ball joint separator tool, buy or rent. Friend has a press to get old ones out, and will make the Home Depot tool to install. I am sure I will be back for more help.
The really is no need to buy a ball joint tool. The uppers come apart with very little effort from a pry bar. Use a hammer (strike the nut) for the lowers. Been doing it this way for years. Quick and easy.
The upper DOES separate easily, on the lower I prefer not to "beat it off", it'll work but the alloy gets all dented up, I know because I've done it. It's just cosmetic, but still leaves the arm looking like you wrapped the car around a pole or something.
