Viper
Old 09-28-2012, 03:44 PM
BuckeyeZ06
BuckeyeZ06's Avatar
Default Viper
Just a heads up (I know this is a Corvette site):
2006 Dodge SRT10 Coupe; track record-holding Viper is available in any configuration the buyer would like. Very motivated seller offering the car from turnkey to roller, racecar to very safe and affordable TT or trackday/HPDE car. This is the fastest NASA and SCCA raced Viper as proven the last three years.
It is a 2006 SRT10 coupe with a very safe, roomy well-designed rollcages built by Mark McMahan (does all of the HART/Honda Racing cages).
Brakes and Suspension: A-arms are Comp Coupe pieces with monoballs. Moton 3 way adjustable shocks. Long ARP wheels studs in the hubs with 2 piece Baer rotors front and rear, stock Brembo calipers and ACRX style cooling ducts. Custom Speedway Engineering swaybars with the rear driver-adjustable.
Car currently has Tilton triple disc 7 1/4" clutch, Tremec T6060 transmission with .80 fifth gear and carbon fiber syncros, a REM'ed 3.07 rear gear with OS Giken differential.
The complete ACRX aero package is installed on the car including upper and lower canards, splitter and wing.
18x11" Front and 18x13" rear Forgelines with Hoosier A6 315/30's on the front and 345/35's on the rear. This is the tire combo used at SCCA and NASA events. OMP halo seat, right side net and electric fire system.
The car is now available without the engine for $45,000, everything else as above.
This is a great handling car! Night and day difference between it and stock. 2:15's at Road America breathing through 53mm inlet restrictor, 3350 lbs and using DOT tires. 2:14s are very possible in this configuration. Take the weight out, remove the restrictor plates and use real slicks...2:12s.
Many spares available including stock suspension arms, calipers, fuel pump, T56 transmission, driveshaft and mount, 3.73 with Quaiffe differential, and other ring and pinions. Too many others too list.
Car is located near Akron, OH
If interested please text 330-289-0536 or email xr4racer1@att.net or wrpinvest@aol.com.
Old 09-28-2012, 11:55 PM
andy3101
andy3101's Avatar
Great race car, great race driver selling this car... I have seen this car first hand and it is well put together and well taken care of... oh yeah, and FAST!!!!!
good luck with the sale, and if you don't sell, looking forward to racing against you next season if you are still running STO, or whatver class we fall into..
Old 09-29-2012, 06:45 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Pics?
Old 09-29-2012, 08:34 PM
BuckeyeZ06
BuckeyeZ06's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 09-29-2012, 08:36 PM
BuckeyeZ06
BuckeyeZ06's Avatar
Pictures of cage (from 2010 during build):
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 09-29-2012, 08:38 PM
BuckeyeZ06
BuckeyeZ06's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 10-01-2012, 02:16 PM
phxcobra
phxcobra's Avatar
Come to Beavis, uh huh huh. If only I had a money tree in the backyard. Or press like the Fed...
Old 10-01-2012, 04:39 PM
BuckeyeZ06
BuckeyeZ06's Avatar
This would be a great DE or TT car; put a stock motor and trans in it, with headers you'd be at 485 RWHP. Safe and fast, and you don't have to trash a neat street car.
To Viper
Quick Reply: Viper
