Got the battery relocated..
After having it come loose at VIR in July and resting up against the exhaust manifold, I decided to move it to the rear of the car.
Here's what it looks like now:
You need to cover up the positive terminal, but you know that. I am always worried about the battery and the wires, but my trunk gets pretty busy after the event. Some high quality loom and locating clamps (like from McMaster) might save a headache.
I'll be tidying it all up over the next couple of weeks.
I've left room at the top for the Cool Shirt cooler.
I'm in the process of doing the same thing. I made a protope aluminum box that fits in the right rear storage compartment. The box itself fits flush up against the front/rear walls of the compartment and will be bolted through the tub. The prototype will not be used because I've come up with a different hold down setup and the new box is made of thicker material and simply much nicer.
Here is the prototype:
Here is what I have so far for the new box:
Supporting Vendor
Hi,
Thats a clean setup.
What kind of little battery is that? I'm sure its a lot lighter than a standard
battery. How well would it hold up for street use?
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Mine is an odyssey 925. It's never been a problem mounted in the stock location as far as street use. Rear mounted with 1 guage cable it should be fine. I will know once I get some time to finish up the install. The reserve capacity is a little less than a larger size battery so if one were to leave the lights or something similar on it would drain much faster.
The battery above mine is an optima. I have rear mounted those multiple times on various cars and they work well.
In my case I already had the odyssey so I simply made the box to fit it. It's not something most auto parts stores carry in stock, but easy enough to get in a day from summit that I am not limiting myself by building the box to only fit that battery.
