Stilo helmets
Stilo helmets
Anybody hear of Stilo helmets before?
They are pricy, but I'm seeing some amazing weights, like 2.6 lbs.
I see 2 light weight models.
http://stilo-usa.com/helmets/wrc-des-zero-8860
http://stilo-usa.com/helmets/wrc-des-carbon
My biggest concern is weight, and not many helmet manufacturers advertise their weights.
They are light, but they are VERY small. I live near the importer and have seen them . their XL is about a M for Simpson. They have very cool features like built in comms and Hydration, and look a bit like a Stormtrooper helm for some models. Also they are very pricy
If you want a more reasonably prices alternative look at the HJC SI-12. It weighs in a little under 2.9lbs and they street for around $699. So around $1100 less than the cheaper Stilo helmet that you linked to and an amazing $6800 cheaper than that ungodly expensive first helmet.
Received 8,919 Likes
HMS Motorsports brought a full line up to the GVCBMW Club HPDE at Watkins Glen a couple of years ago. Very, very, very nice. Pricey, pricey, pricey.
Bill
Bill
If you are going to spend that kind of money on a helmet look at Stand21 and get your self a full custom made and fitted helmet. They are used by a lot of the higher end Pro driver segment i.e. F1, DTM, Rolex etc. etc.
I am considering the $1800 helmet. The other one is 2 OZ lighter for a professional sponser to buy at the $7500 price tag.
$1800 for a helmet, while on the expensive side, it's less than you spend on a motor, or transmission, or 2 sets of tires.. or on an oil cooler which is probably unnecessary, but it makes you feel good
While you may not notice a heavy helmet today, your neck can only tolerate so much abuse and bouncing around. I won't get into details, but I havn't drove since Aug 2008.
I would like to get well below 3lbs. With a collar supporting the weight of the helmet, and then I will be able to get back into the sport of driving.
talking about stand 21, I tried on a Stand 21 many years ago. It was defective, and scratched my entire face trying it on. And there is only one importer of stand down on Georgia, and they were not too helpful.
Lol, got ya. If you've suffered neck injuries in the past then a few oz less I can see might justify the cost. If I can make a suggestion try out the helmets if you have a good race shop local. Because while weight is obviously important helmet fit is number 1. If you do not have a local shop then try one of the on-line guys like saferacer that takes returns. Order both, try them on for a while and send back the one you like least. I came from motorcycles and always only bought the top of the line Arai helmets as I've always felt that when it comes to safety money is not a factor. Having said that though in doing my research the SI-12 came up as one of the lightest helmets on the market and I'm completely happy with the weight, fit and performance of it, hence the recommendation. Either way though good luck and welcome back!
