Help with valve spring kit please.
Cam is the Texas Speed Magic Stick 3 237/242 .603"/.609" Camshaft with TFS 225 heads (rest of mods in sig) and YT rockers. I got 20 track days and 1 1/2 yrs out of TFS springs before breaking one. A lot of choices. Are the BT racing spings overkill? Here is the sale thread with the most choices:
http://forums.corvetteforum.com/c5-p...-kit-sale.html
TIA
TIA
TIA
TIA
That is a donkey dong cam for track use. Definitely annual spring replacement. I think the Y-T rockers are rated to 400lb (unless you have a fancier version than is typical), so be careful. It might be worth it to call various mfgs to see what they recommend.
Just ordered a set from Brian Tooney racing. I got a set similar to the ones I had - knowing I will be switching these out annually now. I got yr and a half and 21 track days out of originals before it broke. Doesn't seem like a big deal changing, except this time I have to pull head to make sure there is no valve/piston damage. I did a whole track day with the broken spring and a dyno pull. If I knew then what I know now, I would have went with a different cam. Oh yeah, and I wouldn't have married my ex-wife either.
