Can anyone recommend a 4pt harness?
hey guys, looking to pick up a 4pt harness for my Recaro Pole Position seats..I keep reading about Schroth being the more preferred brand. I'll admit I am a little confused to it all because their website has many different versions.
Can anyone point me in the right direction??
I appreciate that, but I will not be doing any track racing with the vehicle. The stock seat belts do not fit with the Recaro's so I have to move to a harness either way.
4 point NO.
not allowed on the track. Need the Stock DOT 3 point or 5 or 6 point harness.
6 points are best to so the family jewels dont get squeezed
Unfortunate most states will not recognize anything but the stock 3 point.
Again, not tracking the car...although you did just make the family jewel quiver in fear lol
If you're looking to replace your OEM 3-point with 4 point racing harness, you may want to look for a harness w/DOT approval so you don't run into any problems w/state safety inspection requirements. If I recall correctly there is only one such 4 point, and I'm suffering from a senior moment and can't recall the brand. I'm sure somebody will chime in - hopefully before I can recall the brand.
I think that the reason that people are pointing out that 4 point harnesses are not race legal is because honestly they are not safe. If you are going to pickup a harness get a 5 or 6 point (jewel saver). The reason that you want the 5th or 6th point is to stop you from sliding out from under the harness in the case of an accident. You can choke your self or break your neck if that happens. Again it's 100% a safety thing and honestly not something that you should do without. In regards to harnesses I personally have Schroth Hybrid II's in my car and they are easy to get into and out of with the cam lock system and i would highly recommend them. The difference between getting into a 4 point and a 5/6 point harness is only a few seconds so it's not a lot more hassle or complicated.
Here is what you need. You need to figure out how to mount it and then buy the correct shoulder straps. This url will show many different types of mounting. Speaking from working with cops for the last 30 years, they don't know a DOT seatbelt form a non stock one. I don't know what kind of vehicle inspection you might have, but they might be more aware of DOT regulations. Now for the good news, DOT reqires a push button release and the Schroth has just that.
good luck
http://www.google.com/search?q=schro...w=1600&bih=685
good luck
You really need to check your state laws regarding the use of a 4-point harness. Some states may not allow anything other than an OEM seat belt/shoulder harness even if a multi-point harness system has a DOT approval. One thing that LEO's look for in enforcing seat belt laws is the shoulder belt coming down at an angle across the chest. With a pair of shoulder harnesses, that could be hard to see especially viewed from the rear.
The purpose of the sub belt in a 5-point system (regardless if you are racing, doing track days or even autocrossing) is to keep the lap belt from rising up either from impact in an accident or even tightening the shoulder belts too much. Raise the lap belt and you can slide under it in a collision. If you really want a multi-point system for the street, you need a 5 or 6-point system mounted properly. And worn properly.
I had a Schroth ASM Rallye 4 in my last car (2005 GTO with stock seats).
http://www.hmsmotorsport.com/store/s...allye/rallye-4
However, the installation instructions (available on that page) are very specific about mounting points. The harness is designed to mount to existing seat belt mounting locations. Since Corvettes don't have rear seats there are no points behind the driver. I would call HMS and discuss your mounting strategy before buying a 4 point harness for your car.
http://www.schrothracing.com/store/C...m/profi-II-asm
The ASM feature will make this 4pt. harness acceptable at many PDX HPDE events. They can be converted to 5 point. The red push button release is street legal as opposed to the cam lock. I run these and they are great for a streetable track car.
I agree that the harness mounting is critical.
Received 8,919 Likes
The reason the Schroth harnesses and others aren't permitted in the Corvette is because they are not designed or approved for use in the Corvette. The Schroth harnesses are approved for a few BMWs and some ricers. They have DOT approval since they provide the same protection as a 3 point harness. They do this by fastening into DOT approved safety harnesses latches already installed in the vehicle and by having weaker inside shoulder belts than the outside belts. In a crash the inside belt stretches more than the outside belt thus allowing the upper body to pivot forward and to the side like a 3 point allows. This keeps the body from submarining under the lap belt. Since the Corvette doesn't have the DOT approved mounting points for the shoulder belts to fasten to it isn't safe to use the belts in the car. Mounting them to a harness bar may work but nobody knows. The harnesses are designed for specific cars and tested to meet DOT requirements. Once out of the design parameters you have a crap shoot. Just like with Race Harnesses you can be stopped on the highway and be fined for not wearing seat belts if you have these harnesses in your car since they are not street legal.
You can get a complete run down on the harnesses by calling the Joe Marko the owner of HMS Motorsports in New England. He is a renowned safety expert and is very familiar with these harnesses and where they do and do not work.
Bill
Bill
CI 4-5-6-7 Veteran
I'm just a washed up engineer, but wouldn't wearing a harness on the street without a helmet and HANS keep your body from reaching the airbag, but allow your neck to stretch until your head reached it? POP
I run rjs 5 point on my stock seats, gf will sometimes leave the crotch belt off making it a 4 point for her.
