Active handling defeated!
#41
talking about wet laps... here is mine from Spa-Frankorchamps.. though in m3, but TC really helped out with lap times, I just couldn't move with TC off.
#45
Received 8,928 Likes
I posted this info in a couple of other threads but it seems appropriate here. A couple of weekends ago I tried a couple of things on my 08.
The first thing I did was to put sensors in a canister and pressurize them to 35 psi. Worked fine for exactly one half hour and then the car said Service Tire Pressure Monitor and all 4 tires were reading XXX. Car did not apply both front brakes in turns so it wasn't trying to slow me down to 55 mph. AH may have been reactivated but I didn't get to try and see if I could get it to react since the session was black flagged. I can drive a lot of laps with everything but TC on and never have AH react unless I do something awkward to force it to react. At the beginning of the next session the car was reading the sensors again and I got another half hour without complaint before pulling the car back into the garage. The next time I tried to go out the car had only recognized three of the sensors and I barely got out of pit lane before the brakes were being applied to slow the car to 55 mph. I don't think of that as AH which reacts to control yaw not speed. I limped around the track and returned to the garage. Half hour later the car was reading all 4 sensors and was good to go. The lesson to take from this episode is you don't need to put the sensors in a canister. Just park your car near your street tires with the sensors installed and you can get the same thing without buying extra sensors and building a canister.
The next thing I tried was pulling the steering sensor connector. My car has the orange comb thing in the connector so the connector was fairly hard to get apart but with some help I got it. Car ran fine after that. I pulled the canister out of the rear cubby and sat it on the work bench and the TPMS was happy sometimes but with the sensor disconnected I didn't have to wait until all 4 sensors were being seen by the car. I still had to turn off TC but I wonder how effective it really is without the steering sensor. The early C5s were ABS and TC only cars and all of them had steering sensors which worked with the TC. It probably isn't a good idea to keep pulling the connector since it isn't one of the high repetition connectors. It looks like the best place to install a switch is somewhere near the underhood fuse block where the +5 and low reference signals for the sensor come from.
Bill
Bill
#46
Bill, if you are using a pressure canister the TPS sensors need to move around a bit otherwise they go into sleep mode. What I did was just stick the canister in the rear cubby hole and with the G's from braking and turning it seems to keep the sensors moving around enough to transmit all the time. Otherwise before you go out on track just give the canister a firm shake for 30-40 seconds before you strap in and the sensors will transmit to the car giving you about 30 minutes or so of time before they blank out.
If you do figure something out as far as how to mount a switch or something to disable the steering wheel position sensor please keep us informed.
#47
raising the dead here
why not just pull the fuse that is what we did.. i had just put on some stickys,,I was running the front straight at Homestead and out of nowhere just before T1 the front right locked up and pulled me towards the wall and just scared the s#$t out of me.. My buddy Brent from Performance tech pulled the AH/Abs fuse and i have never had any problem .. My Car is a full track car.. this may not be a good idea if you drive it on the street..
edit - I still have mag ride shocks so if this disables it then I can't do it. If it only disables AH and ABS then I am all over it.
#48
Which fuse is this? I have a 2011 Z06 and under hood I have three fuses all marked ABS (two minis, a 10A and 25A, and then a 40 A). None of these say AH next to them. The 10A had ABS / MM something or other, but in fact nowhere do I see any fuse marked AH.
Pulling the connector on the steering sensor just kills AH so you can still use ABS if needed in an emergency (like oil or coolant on the track).
Bill
#49
thanks Bill, you have been a huge help to me on a few topics now!
edit - removed fuse #11, 25A ABS and drove it around at lunch today. AH and TC are shut off and the ABS and brake lights are on and three messages post to the dash which of course pushing any button overrides back to the display you care about. Other than the lights and messages the car drives fine. I shot thru some turns on a back road to get the Gs up as well and nothing kicked in or acted up so I believe I have my zero cost fix!
Thanks again.
Thanks again.
#51
Thanks to 09ZR1guy for kicking this back up. I had not seen it and wish I had.
I never had any success making the canister. It would leak down too quickly. so I've run my C6 w/o TPMS and have had an issue only when battery voltage drops and it resets the TPM to read zero. UGLY.
I've also had a recent problem with my C5 not being able to (at times) not being able to turn off TC We think it is a faulty steering sensor issue. Apparently not uncommon on these cars. Looks like disconnect will help that.
Just another reason to look forward to warm weather to check it out.
#52
Fuse 3 ABS/MRRTD 10 A supplies both the ABS (EBCM) and the Ride Control. The other two fuses 25 and 40 amps are for the ABS (EBCM). Kill the EBCM or the BPMV (gets its power from the EBCM) by pulling those two fuses and you won't have any nannies.
Bill
Bill
The last two events, I've done laps w/ the steering wheel sensor disconnected after discussions w/ Bill Dearborn. TPMS is disabled, AH is disabled, ABS is active and TC is selectable via the AH mode button. My car is a race prepared 2006 ZO6.
The DIC indicates Service Active Handling and flashes low tire pressures. These can all be zeroed out w/ the reset button.
Jim
#53
I agree with a previous post that noted the steering sensor plug was not designed for repetitive removal/install cycles. Does anyone know what wire(s) specifically need to be disconnected? I may try to rig up a toggle switch so I can switch between track and street modes.
#54
post it so i dont have to go thru the hassle of doingit wire by wire lol
#55
Disconnet the yaw/acceleration sensor (behind the radio screwed to the tunnel) instead, it is a more robust connector and provides the exact override/defeat that disconnecting the steering angle sensor does.
#56
That may work too but I think it's a bit harder to access the sensors
#57
One more validation for the steering sensor fix. '07 Z06, I pulled the steering sensor and had three fast, fabulous days at Road Atlanta on brand new set of R6's. All nannies disabled, ABS still active. This fix made all the difference!
#60
