Harness mounting help?
Hello
I recently purchased corbeau A4 seats and corbeau retractable belt and harness. If you aren't' familiar the two over shoulder harness strap's feed through the holes in the seat back and clip into the retractable mechanism. I need to mount the mechanism around 3 feet minimum behind the seat and could go as far as right to the far rear.
Any suggestions where to mount the mechanisms on a c5 vert?
Hello
a harness bar will be right behind the seats way too close from your description
Hello
with coupes or FRCs the harness bar is used.
for a vert and to have the shoulder harness work properly the waterfall tonal cover may have to be removed.
