does the airdam reduce drag?
While the airdam obviously adds drag by being in the way, I have also read that by reducing the amount of air coming under the car, an airdam can help reduce drag.
Looking at the katech aero charts, when they removed the airdam to put the undertray that connects to the front splitter, they had more drag than with the splitter and airdam alone.
report:
http://www.katechengines.com/street_...a%20report.pdf
any thoughts on this?
report:
Keeping air out from under any car greatly increases the aero over allowing air under the car. Just look at any landspeed car. They go to great lengths to push the rules to the limit to allow the largest air dam possible.
in bottom breathers, the OEM air dam deflects air into the radiator. I personally feel it is useless in the C6Z06, although a prominent Corvette engineer tells me that it somehow deflects flow toward the brakes (not the ducts, but directly to the brakes).
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
The air dam on the Z06/ZR1/GS cars are all there for MPG, nothing else. If anything they create a small amount of lift to the car.
On a land speed car, you'll notice that air dam is right at the nose of the car, not 2 feet behind it allowing it to pick up on the body work.
On a base C6 or C5 car, they are all bottom feeders, so pulling it off of those cars without seriously reworking the air flow through the radiator is going to upset the cooling for the car a lot.
Of course when adding a splitter to the car, it would be wise to remove, some if not all of it.
Track Junky
Former Vendor
On the Z06/ZR1/GS cars this is blocked off, forcing all of the air into the radiator from the grill and not the bottom of the car...thus making it a front breather.
Track Junky
The base cars take in air for the radiator/oil cooler through both the grill and also the bottom side of the car. If you jack up the car you can see the radiator and the bottom of the nose is curved up into that area just like it is on a C5.
Your thoughts?
gs and z06 have large external oil coolers added. ZR1 and some Z06s come with water cooled oil coolers. Base models get neither, although in the past they have gotten oil coolers on the z51 packages which at first were just an oil line running through the radiator like an auto trans cooler, then later the z51 oil cooling setup was changed to a mini version of the external cooler that the z06 got.
I havent compared them in person but from images the opening of the bumper looks the same size as the base. I think its the extra oil cooler and the effect that the front splitter has on the air that helps the temperatures out.
Track Junky
gs and z06 have large external oil coolers added. ZR1 and some Z06s come with water cooled oil coolers. Base models get neither, although in the past they have gotten oil coolers on the z51 packages which at first were just oil ines runnning through the radiator, then later it was a mini version of the external cooler that the z06 got.
I have a 2005 with a dry sump LS3 and Z06 oil cooler. I struggle with getting oil temps up on the street (i made a custom oil cooler shield to help) but keeping them below 270F on the track is a challenge here in south Florida.
If I decided to get a front splitter and lose the air dam, would I suffer any cooling penalty or would the "front feeder" aspect of this setup not increase oil (and coolant) temps?
Sorry to be vague in the first couple posts, I was looking for generic differences so I could apply to my setup.
Good info. Let me clarify then...
I think it would heat up more in in slow or stopped traffic than it does now because there is little air flow (which might help you warm up problem - other option is get an oil cooler radiator which will act as a warmer on a cold start up and then run the exit lines to the external cooler). But at speed I think the splitter would force more air into the front of the bumper and help keep things cool (although it might not be as cool as with the front and bottom openings).
Hopefully someone with first hand experience can expand on this...
Track Junky
My car is a Z51. I moved to a Z06 cooler to help on the track. My main concern is track temps as the car is 80-90% track now. The Z06 cooler prevented me from taking cool down laps mid session but if I push hard, I can still hit 270F with 11.5 qts of oil on tap.
I'd really like to know if moving from a base model setup to a front splitter (air dam delete) will help street AND track...
I may be an isolated case as I haven't converted my car to track only.... Yet. Maybe the wife will let me cage it for XmasI love you honey (if you're monitoring my addiction...)!!!! Hope Santa is listening after the BBK is done...
My guess is that you need a better oil cooler. Setrab 34 or 40 row with -10 lines. You should get plenty of air flow if you only front feed (assuming no obstructions). Going to a single big puller fan will help too.
Since you have a dry sump (what kind??) - you can run a second oil cooler on the run from the scavenge to the tank.
Track Junky
I'm only running a stock LS3 dry sump from a 2012 GS. I have added the Avaid baffle in the oil tank and plan on adding the oil pan baffle when I find a reason to break into the motor. My fog lights are already taken from brake duct cooling so no double cooler for me right now. As soon as the car becomes track only, the interior will get stripped, AC out and everything else that isn't needed. Then I will probably address the oil cooling.
Hi taken19,
I have a C5 Z06 with the stock air dam, and suffered oil temperatures at Homestead that would be at 280+ degrees after only six laps. I purchased an external oil cooler from Mr. Henry Gilbert of 'Hooked On Driving' located in the Miami/ Ft. Lauderdale area.
It is a seven quart total system now, and I add an extra quart just for good measure. From constantly looking at the oil temperature every lap in the past, I almost never look at it now as it runs 230ish even in the hot summer months.
I hope this helps sir,
Jack
Jack
Former Vendor
Actually found a pic from another thread on here..
Z06/ZR1/GS nose (from dfinke23)
Base C6...notice you can see the radiator...
The C6 and Z06 grill opening is close, but the Z's should be slightly bigger. For what you are doing with the car I do not think you would have any issues blocking that off, and if you are going to install a splitter, you should block it off and pull the air dam.
Track Junky
Hi taken19,
Jack
Jack
That looks like turn 6 at HMS in your avatar. Also, I see that red Ferrari behind you almost everytime I'm there - very fast. I've clocked him running high 1:20's at Homestead!
Received 8,919 Likes
Bill
"That looks like turn 6 at HMS in your avatar. Also, I see that red Ferrari behind you almost everytime I'm there - very fast. I've clocked him running high 1:20's at Homestead!". taken19
That's the turn, and if you look closely there is a 2013 McLaren tucked under my rear bumper. LOL if you think that after unwinding the wheel I was still in front of them! They passed me and after coming out of turn 8, they were already turning down into turn 10. Oh well.
I have 40+ track events, and one thing I learned is that Henry Gilbert knows Corvettes regarding track days and racing more than any person I have ever met. He is an honest, and extremely knowledgeable person along with a professional race car driver that will never lead me astray.
My HPDE Corvette page with Homestead stuff if you want to take a gander sir. In advance... I NEVER said I was fast!
http://www.fishme.com/vettez06.htm It ain't that exciting.
Jack
Jack
Track Junky
Jack
Jack
