Torque shaft torx bolt removal tips..
Old 11-11-2012, 11:12 AM
bags142
bags142's Avatar
Default Torque shaft torx bolt removal tips..
I posted in general forum, but figured I may get more help here...
I got the torque shaft and tube seperated.. that 6 inch retaining clip is serious!
But, I am having issues getting the 6 (50) torx bolts removed for the couplers/guido. It is to small of an area to hit with a big impact gun and I am concerned about hurting the torque shaft. I shot some lube on the bolts and using a strap wrench and a socket with a pry bar is getting me nada.
I was concerned about hitting it with a torch and distorting the metal... so I figured I would ask for any tips??
Bags
Quick Reply: Torque shaft torx bolt removal tips..
