I heard a TTA drover ran a...1:...
38'ish on Saturday at CMP.
What did you hear, Mark?
I was actually 7 pts over for TTA. TT3 spec will be 5,000 pts over for TTA
I had never ran new tires with the M6 gearbox there. When you can use WOT in 2nd gear...you can scoot around there pretty good. I ran in Feb with the M6 but it was only with used tires.
I ran a 1:41.1 on 245s on saturday, boy you talk about having to stay on your toes I knew they would suck on a tight track, but I wanted to see how bad
congrats dude! what tire size did you use? 275's?
what suspension?
what suspension?
wow love it. so pretty much just the mn6 swap.
how much do you think coilovers or stiffer leaf springs with "good" shocks get you?
for CMP, I think the OEM springs (as long as you aren't running the car at like 3300 lbs) are just about perfect. I might would try something a little bit stiffer, but I wouldn't expect much in results.
you'd go faster with T1 springs or coil overs.....no doubt...! You just don't realize how soft the OEM springs are until you drive a real race car with stiff springs.
Great run though!
Great run though!
I just dunno how much you'd gain going real stiff there? It would be interesting to test. Also working the tire harder on a track that's already brutal on tires.
IMHO the nose pitch under braking is probably the weakest link with the stock springs. The feel is good, seems the stiff sprung car you end up going through a corner "because you should be going this fast" not because the car is talking to you.
