spindle ducts
spindle ducts
I got some .090 sheet aluminum for all of 0 dollars and I was going to make some spindle ducts like the Quantum ones.
My question is will .090 be too thin for this?
I ended up using the .060 rather than the .090
preliminary measurements
Back side
I don't need to "strap" the caliper side around the inside of the spindle because the .060 fit in between the chamfer of the hub and the spindle.
I just had to keep filing and fitting to get a perfect fit.
Back side
Good job!
I'd "personally" take them someplace and have them welded...brackets and all. It'll survive a lot longer.
You don't want one of those coming apart on track....
Here's a link
http://www.aircraftspruce.com/catalo...uctflanges.php
Do yourself a favor, spend the $20 for the right flange adaptors. It's cheap insurance.
My buddy has a tig welder but that stuff is real thin, Id hope it doesn't blow a hole right through. Maybe Ill have him weld those flanges on instead, they look beefier.
Thanks for the link.
Heres what I did for NACA ducts
destroyed fog lights
Carbon cone
wet out
Rough edge before I added more carbon to even it out for flexible hose attachment
Carbon cone
wet out
Make sure you shim your calipers. If not, you will have rubbing of the caliper pins on your rotor. Also, I mounted my 315/18 Hoosier slicks and they rubbed the hose.
I never unbolted the hub to install them, just wedged them in.
Received 1,722 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Other than that they look nice! A couple of those flanges would be good to add for the hose.
That looks a lot stronger....
Also, as you rivet stuff like that together, it's good practice to use stainless rivets, and put the proper stainless rivet washers on the back side of the rivets, makes them much less likely to pull out of the thin aluminum.. Or you could put the flanges on the outside and have the heavier aluminum on the back, again, less likely to pull the rivets out when the tires are turning and bouncing around.
that looks great, if you could make a "template" to share (pdf etc) that would be great. A few key measurements for calibration (pdf's don't always print at the right size)
hard to tell in the photo, but does it extend downward far enough to protect the lower ball joint boot also? Nice-mult-solution design!
Yes they cover the ball joint but there is a section that still covers the "fire path" should I trim it off? With the X on it.
Ill see what I can do about a template but they're still not perfect.
