How many track days between flipping R6 tires?
I drive in advanced grp in s fla and do 5 25 min sessions of hpde on Hoosier r6 tires. I usually remount turning the inside of tire to be on outside after 3 trk days, what do u guys do? I also chg right to left tires betw events
Depends on your camber, bushings and driving style. But whenever you see a decent bit of wear on the outer shoulder is the easiest guide. I wish Hoosiers had squarer shoulders like BFGs.
I was gonna flip after 2, but I guess I'll keep it at 3 events. Mine were done after 5-6 events as well
As mentioned above, it all boils doen to monitoring the air pressure and wear rate. These factors will be determined by the camber, driving style, the track and surface, etc.
