Which of these tire sizes will be best at the track?
Old 12-22-2012, 12:33 PM
dbs1vette
dbs1vette's Avatar
Default Which of these tire sizes will be best at the track?
1. 275/40/17 F. 315/30/18 R.
2. 315/35/17 F & R
3. 315/30/18 F & R
4. 315/35/17 F. 315/30/18 R.
I am currently running #1 which has worked well, but am curious if either of the others might be an improvement? For the most part car is very predictable, but at times will want to come around and surprise me.
Old 12-22-2012, 01:09 PM
kmagvette
kmagvette's Avatar
Square setups like 2 and 3 work well. I currently run 305x18 (dry) and 275x18 (wet). I used to run 18x315. I run on the same wheels so I can swap things around at the track to manage wear.
Old 12-22-2012, 02:12 PM
GT Racing Tires
Supporting Vendor
GT Racing Tires's Avatar
LOADED Question! Many variables such as car set up, weather, track condition, the track itself (layout) and what the driver likes.
You really don't know unless you have the time and money to do testing. Stick with what you like.
Old 12-22-2012, 02:27 PM
2MCHPWR
2MCHPWR's Avatar
if the rear comes around and surprises you, try lowering air pressure in the rear tires. Try softening the rear bar if it is adjustable or put on a smaller rear swaybar (I used T1 up front and stock in rear). Also try softening the rear shocks if adjustable. Only do one of these at a time. if the rear comes around on corner entry, don't trail brake; do your braking in a straight line to see if that helps it.
if the rear comes around with 295's up front, putting 315's up front will make that worse because you will give the fronts MORE traction. edit - if you get the handling situation under control, I would think 315's all around would be the fastest combo.
Old 12-22-2012, 07:55 PM
dbs1vette
dbs1vette's Avatar
Well I don't know what my "favorite" is yet as I have not tried them all. I have had very good success on the bigger/longer/faster tracks with the current combo. It's the shorter/slower tracks I'd like more cornering grip on. In fact, would one dare try a 315/17 on the current 9.5" front wheels if they were planning to get wider ones anyway? Downside?
Old 12-23-2012, 10:26 AM
braknl8
braknl8's Avatar
315's on a 9.5 wheel is a bit much, I believe.
To Which of these tire sizes will be best at the track?
Quick Reply: Which of these tire sizes will be best at the track?
