WTB roadracing camshaft
Old 12-24-2012, 05:09 AM
BossV8
BossV8's Avatar
Default WTB roadracing camshaft
I Am looking to buy a "soft" camshaft for road racing. I am thinking GMPP ASA or Hotcam. Easy on the valve train that I want to keep stock.
I need like new quality. Thanks.
Old 12-24-2012, 11:02 AM
GettReal
GettReal's Avatar
In case you can't find a lot of those out there, I'll suggest this cam as well. Its been an amazing cam for the track, I've now used it it 2 of my road race motors. Lift is still easy on the springs and this cam is easy to find.
Comp Cams RR
232/234 595/598 112
TSP also carries the same cam under their name
TSP Torque 2
232/234 595/598 112
There is a forum member named "TriplBlk" and he had a ASA cam for sale a few months ago. Search him name and shoot him a PM
Old 12-24-2012, 12:14 PM
BossV8
BossV8's Avatar
Thanks about triplblk but he has sold it.
About the two cams you are mentioning: the lift seems big to me as I want to keep stock Valvetrain.
Old 12-24-2012, 01:15 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
The GM Hot cam is low lift, but big duration, due to rules limitations. It makes good power, but you really need tuned headers and a no restriction exhaust or you will be inhaling more exhaust fumes than fresh air during overlap!
Old 12-24-2012, 01:24 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Depends on if you have any rules to follow.....we have ground different cams for road race applications.
Just call us and ask for a specific RR version!
Old 12-24-2012, 02:34 PM
BossV8
BossV8's Avatar
I have ARH headers with cats and GHL mufflers. I am just good on sound test here in France.
Do you think it can be a problem?
Old 12-26-2012, 05:13 AM
BossV8
BossV8's Avatar
I have no rules to follow, except for sound level.
Do you propose camshafts that allow to keep stock valve train?
Old 12-26-2012, 09:46 AM
Former Vendor
Springs of course would have to be changed but I see no reason not to keep the factory rocker arms in the car.
Old 12-26-2012, 01:06 PM
BossV8
BossV8's Avatar
So it'd be springs and rods?
Old 12-26-2012, 01:33 PM
Former Vendor
Generally in our cam kits, they include:
-Camshaft
-Comp 921 dual springs
-Comp spring seats
-Comp Ti retainers
-Comp valve seals
-Comp pushrods
-C5R single roller timing chain
-Cam gear (depending on year)
-Chain damper (depending on year)
-NGK plugs
-GM crank bolt
Old 12-27-2012, 07:33 PM
TriplBlk
TriplBlk's Avatar
Thanks for that GettReal, I have sold it but I appreciate this
Old 12-28-2012, 12:28 PM
kmagvette
kmagvette's Avatar
This past April I did a heads/cam/intake on an 02 C5Z. My primary goal was not to wiggle the pin in the grenade under the hood too much. I put in a very mild comp cams .571/.573 cam (54-428-11), GMPP Heads, and had my LS6 intake modified to accept a 90 mm TB. The ramp on the cam is totally ***** (as in not aggressive). Rockers are CHE, redline bumped to 7K. I changed injectors as well, 42 lb I believe.
When I had the dyno tune done, I was only interested in getting the fuel/air dead on through out the rpm range...the HP/TQ numbers I really did not care about other than wondering how well money was spent.
The numbers shocked the hell out of me. 447 rwhp and torque that languished around the 400 ft-lb mark for a wide rpm range. I don't recall the exact range, but I think it was similar to 3,500 to 6,000. Dyno was a Mustang if that matters...that was the only time my car was on a dyno so I have nothing else to compare it to
With the bug heads and intake, the car idles has a mildly crappy idle and is prone to stalling. On the track it is an animal. A well piloted CZ6 will still pull me a touch coming out of the corners, but by mid straight I am running them down; no replacement for displacement I guess.
Old 12-28-2012, 01:31 PM
AU N EGL
AU N EGL's Avatar
What duration were those lobes ?
Old 12-28-2012, 01:37 PM
kmagvette
kmagvette's Avatar
228/230 according to http://www.compcams.com/Company/CC/c...csid=1091&sb=2
Old 12-28-2012, 03:04 PM
BossV8
BossV8's Avatar
What components of the valve train did you need to change?
Old 12-28-2012, 11:26 PM
kmagvette
kmagvette's Avatar
I did the CHE upgrade to new stock rocker arms just because I wanted to get rid of the needle bearings; no idea if it was worth it but I know I can't send a needle through the engine since there aren't any. The rockers are really stable.
While I was in there I did normal replacements like lifters and lifter trays. I also replaced the push rods with the suggested 7.40's. Valve springs are comp cams 918...nice, but nothing with unnecessarily high seat pressures.
I used forum vendor Parts Taxi for all the GM stuff...awesome service.
Old 12-29-2012, 02:48 AM
BossV8
BossV8's Avatar
Sorry, what is CHE upgrade?
Old 12-29-2012, 10:22 AM
kmagvette
kmagvette's Avatar
The CHE upgrade was done through West Coast Racing Cylinder Heads (proheads.com). They replace the needle bearings with Bronze Alloy bushings. It tightens up the rocker assembly like the comp cams trunnion upgrade does, but does so without any needle bearings.
To WTB roadracing camshaft
Quick Reply: WTB roadracing camshaft
