Brakes Upgrade
Old 12-25-2012, 06:10 PM
r.hillenbrand
******RETIRED ARMY******
Support Corvetteforum!
r.hillenbrand's Avatar
St. Jude Donor '12
Default Brakes Upgrade
What are the best brakes for the buck?
Wilwood W6A-R compete with Spec-37 Rotors, Pads and lines for $2400? Or something else
Old 12-25-2012, 07:08 PM
ErnieN85
ErnieN85's Avatar
AP brakes from Gary at Hardbar
Old 12-25-2012, 07:45 PM
r.hillenbrand
St. Jude Donor '12
Thanks, I will go to his page and and look.
Old 12-25-2012, 10:15 PM
dvandentop
dvandentop's Avatar
get the t1 kit for that price range
Old 12-26-2012, 11:12 AM
UstaB-GS549
UstaB-GS549's Avatar
Another vote for Hardbar T1 kit.
Old 12-26-2012, 11:26 AM
Charley Hoyt
Charley Hoyt's Avatar
It depends on what you are going to use them for. What car? Track only? Street and track?
The hard bars look like a great option for a track only car....but, the floating rotor design would be loud for a car that spends time on the street. I am leaning toward Stop techs for my track/street application
Old 12-26-2012, 02:18 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
What model of car?
Current wheels, or are you buying new?
Any rules to fit by as far as class, or just going on the street?
You might be fine with pads and lines.
Old 12-26-2012, 06:23 PM
JDIllon
JDIllon's Avatar
Can't go wrong with Stoptech BBK!!! JD
Old 12-26-2012, 06:26 PM
r.hillenbrand
St. Jude Donor '12
Default Brake Upgrade
Anthony,
It is a stock C5Z I use it for HPDE-3 about 8 weekends a year. Adding the Glen and Mid-Ohio this year was told both are hard on brakes. I am using DTC-70 Front and DTC 60 Rear.
Going to VIR in Feb for Instructor Course
I have 2 sets of wheels speedline 18x10.5 all around and CCW's, both clear the ST-60 6 piston Stop-tec BBK.
Haven't decided if I am going to a class.
Originally Posted by Anthony @ LGMotorsports
What model of car?
Old 12-26-2012, 09:27 PM
cruzin2
cruzin2's Avatar
I went with brembos bbk and can't be happier. Used to have to watch the pin bolts closely and bleed them at lunch when at mid o.... Now I just show and run. Brakes are solid for as many laps as I can handle. I think any BBk is a good idea for mid Ohio. Missing the back straight is not much fun.
Old 12-27-2012, 10:27 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
What tires are you on?
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 12-27-2012, 11:22 AM
argonaut
argonaut's Avatar
The AP floating rotor design is pretty noisy for street use. They sort of give of a 'clink, clink' sound at low speed. Not a big deal but really depends on your tolerance for noise. The good thing is the Harbar T1 kit accepts stock rotors - so use stock for street and the AP rotors for track.
Old 12-27-2012, 05:09 PM
JeremyGSU
JeremyGSU's Avatar
http://forums.corvetteforum.com/auto...s-on-a-c5.html
Old 12-28-2012, 09:40 AM
r.hillenbrand
St. Jude Donor '12
All,
Just wanted to say thanks everyone for the information. I went with the W6A-R wilwood setup. It is a bolt on BBK and since I am running 10.5x18 up front and the wheels I have will clear the BBK. I also have the LG Spindel ducts with DRM Brake Ducts for cooling.
Again thanks for the advise. Ron
To Brakes Upgrade
Quick Reply: Brakes Upgrade
