Trailer Lug Nuts
Old 01-01-2013, 01:31 PM
rfn026
rfn026's Avatar
Default Trailer Lug Nuts
I just updated my blog that deals with trailer lug nuts. You don't need to drop a wheel off your trailer.
Richard Newton
Facebook
Old 01-02-2013, 06:52 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
That's a good reminder. I usually try to check the torque on the trailer wheels before I travel, but sometimes in the rush of trying to get on the road, I overlook that step. I think I'll make a "to do" list of things that I need to do before I leave.
Old 01-02-2013, 04:21 PM
Han Solo
Han Solo's Avatar
Haven't checked mine in quite a while but when it was new I had to re-torque them 10-15 times before they quit loosening. My trailer has the standard white steel wheels on EZ-lube hubs. I have seen many a trailer wheel come loose from not being re-tightened. I guess it takes a while for the cheap wheels to conform to the hubs?
That said, both sets of aluminum wheels on my car will require one re-torque after running a spell. After that they seem to stay tight.
Old 01-03-2013, 10:13 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
I haven't checked mine since new tires were installed last year. Need to add to track day cklist. If you don't mind, I am posting the torque specs here for future searches.
Trailer Tire Torque Specifications(from rfn026 blog): Wheels Bolts
M10 - 40 lb. ft. / 54Nm
M12 - 65 lb. ft./ 88 Nm
M14 - 108 lb ft. / 164 Nm
Torque Specifications: Wheel Nuts
3/8" UNF - 42 lb. ft. / 57 Nm
7/16" UNF - 50 lb. ft. / 67 Nm
1/2" UNF - 56 lb. ft. / 76 Nm
5/8" UNF - 85 lb.ft. / 115 Nm
Thanks.
Old 01-03-2013, 03:42 PM
rfn026
rfn026's Avatar
I have no problem with the posting.
Richard Newton
Old 01-03-2013, 11:46 PM
Han Solo
Han Solo's Avatar
Thanks.
I have always torqued my 1/2" studs to 90 FT/LBS.
Here is what Tire Rack lists.
Hardware Bolt or Stud Size ********** Typical Torque Range in Ft/Lbs *********** Minimum Number of Turns of Hardware Engagement
12 x 1.5 mm ********* 70 - 80 ******* 6.5
12 x 1.25 mm ********* 70 - 80 ********* 8
14 x 1.5 mm ********* 85 - 90 ********* 7.5
14 x 1.25 mm ********* 85 - 90 ********* 9
7/16 in. ********* 70 - 80 ********* 8
1/2 in. ********* 75 - 85 ********* 8
9/16 in. ********* 135 - 145 ********* 8
http://www.tirerack.com/wheels/tech/...|b|6698650813&
To Trailer Lug Nuts
Quick Reply: Trailer Lug Nuts
