So many shock choices
Old 01-05-2013, 06:45 AM
heypal
heypal's Avatar
Default So many shock choices
So I have 5 more mod points I can use and stay in my current class. Shocks are only 5 points the rule is aftermarket shocks adj & non-adj (w/stock springs)+5. I think this is where I should spend my extra points its the only real thing that is 5 points everything else is 10+. So with all my choices out there I don't know what to choose. Now later on down the line I'll bump up a class with some a6's or something and throw on some t1 bars but I only want to buy shocks once. I was readying 04 shocks are good if they can be found, then there are JOC shocks, bilsteins, drm bilsteins...any and all advice is appreciated.
Old 01-05-2013, 09:58 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
In SCCA T1, now T2, I've just been using the GM Sachs non-adjustible T1 shocks tuned for the T1 suspension. I don't get enough track time to tune adjustible shocks (to justify their cost). I think the Sachs shocks work well and they are bolt-on without having to worry about setup.
Most of the top tier guys I race with go for the high-dollar triple adjustable Penske's - something like $5k for the car. Very good if you have the time to set them up for each venue. I don't, nor do I have $5k laying around...
Good luck!
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 01-05-2013, 01:35 PM
heypal
heypal's Avatar
Good luck!
Nice yeah that's what I'm looking for something to throw on and make me look great out there lol. And wow at the 5k shocks I'm pass I'm competing on a budget. Thanks for the input have fun in t2 this year and kick some butt.
Old 01-05-2013, 03:19 PM
crimlwC6
crimlwC6's Avatar
I like the Pfadt Adjustable inverted shocks. I got them set in one track day and haven't changed them in a year.
Old 01-06-2013, 07:40 PM
heypal
heypal's Avatar
Cool, I'll take a look at those. Thank you.
Old 01-06-2013, 07:59 PM
MarkDFW
MarkDFW's Avatar
I have the pfadt single adjustable coilovers as well. I put them on the suggested starting point and have their JOC sway bar set to medium. My car is dual purpose so you will want a stiffer setting, but they work well.
Old 01-12-2013, 05:02 PM
heypal
heypal's Avatar
I wish I could do coil overs but that bumps me up a class, so I can only do shocks. Now when I switch to a slick then I'll go ahead and run coil overs . Thank you for the advice though.
To So many shock choices
Quick Reply: So many shock choices
