skf bearing differences.
what is the difference between the SKF bearing that Napa sells for 280 / SKF part number BR 930198 and the 400 dollar units and I see for sale on the Corvette specific sites?
The bearing offered at Autozone is an OEM replacement unit built to the same specs. The $400 bearing is a substantially upgraded unit for racing applications, better bearings, thicker flanges, etc. Stick with the OEM unit for street use. The race hubs are well worth the $ if you track the car, if you have ever seen a failure you would agree.
OEM vs. SKF
In my C5 the wheel bearings rumbled. What this equaled to was just a lot of road noise. I didn't really even realize how bad they had gotten until I replaced them. The braking feel improved the most, followed by the quiet ride.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Not sure the street driving would work the bearing enough to affect the braking but on the track the brake pedal gets a little play in it (soft pedal) because of pad knock back from the rotor deflection. You might remove the rotor and inspect the bearing closely for minute crack around the barrel and flange junction. If the bearing is cold it is difficult to detect movement while pushing and pulling on wheel at 12 and 6 position even on a bad bearing.
Rumbling is a very good description of what I hear. Seems to be from the rear but pinpointing the sound is tricky. Thanks for the info.
If you get the bearing hot (which it will be if it's trying to fail) and wiggle the wheel on the 6-12 axis and the 3-9 o'clock axis, you should feel the play.
Mine failed when I was at low speed. Front right. The car simply would not turn anymore. Lucky I had a place to go off track. The failure was complete. The hub broke at the flange, leaving the brake as the only thing holding the wheel on the car.
http://forums.corvetteforum.com/auto...my-brakes.html
Received 8,928 Likes
Bill
$218..
I've broken the flange on two of the OEM ones.
the 2 fronts and the driver rear is now the SKF race bearings. the pass rear is a new OEM.
I bought a couple of these to have in case of on track failure.
You can test the bearing the old fashioned way, jack up the front wheel, take the jack handle an place it under the wheel and lift up, this will test for any play in the bearing under load--weight of the car. If the bearing is good, the wheel will lift on the spring, if the bearing is starting to wear, you will feel a slight movement before you move the spring.
Premium Supporting Vendor
Simple check is lift each corner with jack and in & out rock the wheel/tire package...any play you can feel with your hand is generally the first indication of failure... sound....low roaring sound (early) and pedal sinking...
SKF OE bearing verses the racing... flange thickness (as shown in earlier post) also the load bearing race has more bearings (better load distrbution) tighter bearing preload and a higher temp grease....
Dan Kellermeyer put over 5000 racing miles and were still good when sent back to evaluation..
The $400. per bearing if you track the car or you are a "spirited" is a good investment when comparing bearings and their features...
Let me know if we can help..
Cheers
Paul
Van Steel
Cheers
Paul
Van Steel
