suspension drop
Old 01-24-2013, 10:16 AM
1stz51
1stz51's Avatar
Default suspension drop
I have a C6 Z51 with stock springs and shocks with a very mild
allignment I do about 6-8 track weekends a year. What has happened is the front end has dropped about an inch, were I can barely get a finger between the tire and fender lip. I was wondering what to look at when I get car on jackstands?
Bill R.
Old 01-24-2013, 10:32 AM
Scooter70
Scooter70's Avatar
Possibly one of the eccentrics bolts has slipped.
Old 01-24-2013, 11:22 AM
el es tu
el es tu's Avatar
shocks could be worn
the spring pads could have broken off of the adjusters
or
less likely the spring could be messed up
good luck!
Old 01-24-2013, 01:15 PM
sperkins
sperkins's Avatar
I'd guess eccentrics have slipped as well. These cars hold they're tolerances well until the eccentrics move. If you're ever in Macon, feel free to stop by and I'll check it for you.
Old 02-02-2013, 12:08 PM
1stz51
1stz51's Avatar
If the eccentrics have moved would that not change camber?
Tire wear has been normal, meaning no abnormal tire wear.
Bill R
Old 02-02-2013, 12:18 PM
Solofast
Solofast's Avatar
Most likely cause is that the front spring is broken. If an excentric had slipped the car would be handling funny, the steering wheel would be off center or the car would be darting around.
If it isn't doing any of those other things, it's most likely you've had a spring collapse.
Jack it up and look for fraying of the spring. Look at the sides of the spring for evidence of it splitting.
It sounds pretty low, is it riding harsh, like it is on the bump stops??? That would also be indicative of the spring breaking..
Old 02-09-2013, 03:42 PM
1stz51
1stz51's Avatar
Ended up being the bushings on the end of the lowering bolts. They were
completly gone.
Old 02-11-2013, 09:44 AM
el es tu
el es tu's Avatar
if you still need replacements you can go with these:
http://hardbarusa.com/hardbar/produc...products_id=48
or these:
http://www.lingenfelter.com/mm5/merc...ode=L500010197
Old 02-11-2013, 01:05 PM
Charley Hoyt
Charley Hoyt's Avatar
Originally Posted by el es tu
Does anyone have experience with these? How well do they hold up? How involved is installation?
Old 02-11-2013, 02:09 PM
sperkins
sperkins's Avatar
I have a set of the hardbar delrin front spring adjusters if anyone needs a pair. $50 shipped. Also have rear delrin spring bushings if anyone is interested.
Old 02-11-2013, 02:33 PM
el es tu
el es tu's Avatar
They both have had good reviews. The LPE is more like the T1 and hyperco vs the rounded hardbar.
There are a few threads on the two.
To suspension drop
Quick Reply: suspension drop
