YAW Sensor relocation on 2004 c5 z06?
YAW Sensor relocation (MTI seat rails) on 2004 c5 z06?
Can the YAW sensor be moved with out upsetting the system?
I just bought a set of MTI seat rails, and there is a mounting location on the rail for the YAW sensor. I'm concerned about moving it because I saw a statement from a HardBar install write-up that says this.....
"GM also has stated not to move this sensor from its location. Any attempt to relocate this sensor will result in the active handling system not working correctly"
Is the YAW sensor that sensitive that it will notice being repositioned 2 inches above the original spot? I emailed Kevin @ MTI yesterday, but haven't heard back yet...so I was just curious if anyone here knows.
Thanks for any input.
The yaw sensor is mounted under the hvac controls. They mean the lateral accelerometer. I just remove it from the bracket (remove the bracket and epoxy from the floor)and either mount the sensor to the seat rail with velcro or, depending on whose seat mount you are using, relocate the production bracket to the floor. Just make sure the harness connector on the sensor faces towards the right frame rail and is perpendicular to the torque tube tunnel.
So, just to confirm..... The sensor under the passenger seat can be repositioned without driviability issues? The quote i posted above was referring to the sensor under the seat ..scroll about midway down.
http://www.2phast.com/Corvette/sparco.htm
Whats the best way to get the sensor out from under the carpet? Remove the center console, or remove door sill plate? I'm sure somewhere some GM engineer had a perfectly good reason to mount a sensor right there and under the carpet
That sensor needs to be as close to the center of the vehicle as possible to minimize the need for sensor offset compensation. The sensor also needs to be protected. Real estate in that area is precious, especially on a small car like the 'vette with other requirements like weight distribution. They got as close as they could.
I got it...the sensor is sitting down on the floor over 2 studs which come up out of the floor, and the sensor is held down with 2 nuts.
I just peeled the carpet back from under the center console, and that exposed it enough to unbolt it from the floor. I made a small incision in the carpet just big enough to pass the harness plug through, then bolted the seat rail down, then bolted down the sensor to the location on the MTI rail using the supplied allen screws, and plugged back in the harness. I took it for a 15 mile drive and so far no errors, etc.
Now I've got to pull the rail out and mount the seat up.
No...the wire harness is not pinched. Hard to tell in the photo, but the MTI rails are tilted....meaning they sit higher in the front than the rear. There is a slight gap under the rails. The wire harness moves freely. Here is a better shot of the gap on a HardBar rail that I googled. The MTI rails sit the same way.....
