ZR1 track tires - choices?
Old 01-31-2013, 05:23 PM
CanadianVetster
CanadianVetster's Avatar
Default ZR1 track tires - choices?
What track tires are guys using on the stock rims.
Seems limited choices in 19/20 inch.
Suggestions?
Old 01-31-2013, 05:39 PM
jvp
Support Corvetteforum!
jvp's Avatar
Received 3,805 Likes on 1,145 Posts
"Ask Tadge" Producer
Suggestions?
If you're stuck on the stock rims, you're pretty much limited to the Michelin PS Cups, which are phenomenal tires but fairly expensive. Some of us are using them, others are running 18" wheels all the way around which opens up a bunch more choices.
jas
Old 02-03-2013, 10:14 PM
isnider
isnider's Avatar
Get a set of 19"x12" repros or Z06/GS rears and you can run Hoosier R6/A6 295/30R19 and 345/30R/19
Ian
Old 02-06-2013, 04:20 PM
Lasco001
Lasco001's Avatar
I have the Toyo R888 tested in 19/20, works very well. Price and performance
The best is for me the Michelin Cup
Cölestin
To ZR1 track tires - choices?
Quick Reply: ZR1 track tires - choices?
