accusump tap in block ?
Old 02-02-2013, 09:17 AM
C5ZEE06
C5ZEE06's Avatar
Default accusump tap in block ?
who knows ??
does the LS6 engine block have a port directly into the oil gallery to tie-in an accusump line ?
thought i saw a thread on this but can't find it.
Old 02-02-2013, 09:55 AM
J.R.
J.R.'s Avatar
you can plumb into drivers side towards front of block.
you need a metric to AN adapter
I believe David Farmer did a writeup on exact adapter size and where to buy.
Old 02-03-2013, 07:55 AM
C5ZEE06
C5ZEE06's Avatar
couldn't find his post so sent him a pm..anyone else know and have any details ?
Old 02-03-2013, 10:51 AM
RX-Ben
RX-Ben's Avatar
Here is a link: https://dl.dropbox.com/u/1634366/accusump.pdf
You can also use a special fitting (Kurt Urban Performance sells it) that goes into the plug at the end of the diagonal oil galley, in the driver's rear side of the block. With this location, you get a "free" one way valve in the form of the anti-drainback on the oil filter, as the above galley is just after the oil filter.
You can do a search for the LS oil galley diagram, in case the above is not clear.
Old 02-03-2013, 11:02 AM
J.R.
J.R.'s Avatar
Found info:
Parker fitting - part # 8M16C8MXS
right angle M16 x 1.5 to AN8
Earls part# 9919FFJERL
M16 x 1.5 to AN 10
Double check part #'s but metric M16 x 1.5 is the correct block thread.
Old 02-03-2013, 12:16 PM
C5ZEE06
C5ZEE06's Avatar
Thanks to both of you for the assist !
Old 02-03-2013, 11:59 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
that is my dropbox link above...I like that port, much cleaner than going with a sandwich or other adapter.
Old 02-04-2013, 08:21 AM
C5ZEE06
C5ZEE06's Avatar
agreed.....Thank You !
Old 02-04-2013, 10:31 AM
waddisme
waddisme's Avatar
I have one of these NIB that I never used. I will make you a good deal. I will send you a pm.
To accusump tap in block ?
Quick Reply: accusump tap in block ?
