Wilwood Brakes
Old 02-08-2013, 09:45 PM
r.hillenbrand
******RETIRED ARMY******
Support Corvetteforum!
r.hillenbrand's Avatar
St. Jude Donor '12
Default Wilwood Brakes
Installing new W6A-R BBK on C5Z. When I put the pads in and slid the pin back in and put the clips back on I didn't like the way they cliped in. Is there another clip that will fasten more securely? Has anyone had a clip come out? Will the clips hold up to the heat and stay in on Road Race like VIR, Summit Point, The Glen and other tracks.
Thanks Ron
Old 02-08-2013, 11:47 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
The clips hold just fine. You do need to make sure they are seated properly when installing them. I install them and then push the pin from the other side to see if they will pop out. I keep my other hand in place over the clip so if it does come out I can catch it. Small snap rings will also do the job. I have a bunch of them that will fit in case I lose one of the Wilwood clips at the track when changing pads. They tend to fly quite a distance at times.
Bill
Old 02-09-2013, 08:34 AM
r.hillenbrand
St. Jude Donor '12
Bill,
Thanks for the information. I stopped last night before cracking the lines from the other calipers and putting fluid in the new ones just incase I even had the remote chance of returning them. I will buy the other rings and finish the install today.
Ron
Old 02-11-2013, 09:41 AM
95jersey
95jersey's Avatar
Never had one fall out
Old 02-12-2013, 05:32 PM
jlutherva
jlutherva's Avatar
Bill
Great brake setup. You'll love it and your wallet will too. I use the "c" clips and have never had a problem with them coming out.
Jim
To Wilwood Brakes
Quick Reply: Wilwood Brakes
