Seats for 2010 Z06
Seats for 2010 Z06
I would appreciate any info on Track Seats for my Z06. I have been searching, and not sure exactly what will fit. Stock interior with center con. and shark bar. I need two seats which:
One: will fit in the space I have in the car
Two: will allow for 6 point restraint harness
Three: that I will fit into I have a 38 inch waist.
Have seen several I like, but not sure on the car fit. Cobra, Corbeau, Recaro, and Sparco.
Any of these brands will most likely work, but what models fit the car?
I have three events with in 30 days and can see and sit in what others have done if I cannot resolve the issue before then.
Thanks for any recommendations.
vz
vz
Racetech seats work great I have a 40 inch waist and fit comfortable. I believe they also sell Sabelt seats
I got mine at MTI racing in Marietta Ga
I put the Sparco slider in as well because my wife & I share the car on track sometimes. I had to pull the 2 bolts that secure the emergency dead-battery-door-opener pull or it prevents the seat from sliding forward enough for the Mrs.
Former Vendor
MOMO Daytona XL
I have 2 of the MOMO Daytona XL in stock that will fit the bill for you. Check the pics and let me know.
MTI Racing Seat rails installed with the MOMO seat
Received 8,928 Likes
Installing Race Seats in a C6
I updated my procedure on how to install two Ultrashield Race Seats in a C6. These are 17 inch seats and will easily fit a person with a 42 inch waist. If your waist is smaller then get a smaller seat. They vary in size from 15 to 18 inches in one inch increments although I think an 18 inch seat may be too wide as mine just fit. Here is a PDF version.
Bill
Bill
Thanks to all for the very good advice and suggestions. Particular appreciation to Cajun for his help. I have decided on the Marrad Seat Back conversion which satisfies my fit concern. Will post pictures once installed.
vz
vz
5th Gear
Racetech RT 4009 whrv
I have some racetech seats they are the rt 4009 whrv seat which is the $2500 seat racetech makes. I took them out of my 2007 z06 that I was using at the track and I really liked these seats. I have a 38 inch waist or did when I bought them and I also have everything that u need to literally take your stock seats out and put these seats in with the same 4 bolts that are used to hold your stock seats in. I can send pictures if u would like. I have 2 of the seats like new $1500 each or I can make u a deal on both. Thanks.
vz
