Hints on adapting C6Z brake ducts to a C5Z
I notice that some folks have used C6Z brake ducts on C5Zs. They seem really cheap.
Any hints on installation?
I already have Quantum spindle pieces and 3" hose but I gather the stock C6Z ducts are just 2.5"
Received 8,928 Likes
Bill
I modded a set of stock C6Z ducts for my C5Z. It was a matter of fitting, then cutting, then fitting, then cutting, until it worked. Not really hard, but it took some time to get right. You are basically fitting a tube into another tube at a weird angle, constrained by the place where the tube passes through the wheel well. Pay attention to the clearance between the duct, the flexible hose you attach to it and the wheels you use, especially at full steering lock. Good luck!
Don't be afraid to take a sabre saw to the brake duct opening in the wheel well to get a different duct to fit. That is what I did when I installed the DRM ducts in my C5Z. Marked the opening I needed and then took the saw to it. Only took a couple of minutes.
Bill
Bill
Thanks for the help folks, I guess it will be a bit of trial and error.
Not really sure why GM put in those big ducts that just go to the wheelwell on the C5Z. When you turn the wheel with a big tire, they direct the air onto the tire surface and no where near the brakes.
