Does this indicate a bearing problem?
Old 02-24-2013, 01:57 PM
Charley Hoyt
Charley Hoyt's Avatar
Default Does this indicate a bearing problem?
I attended a driving school at Willow springs last week and my car started making a metal to metal scraping noise under braking. I assumed that I had a pad failure or that I had burned through the pads.... But when I took it apart the pads were fine and it looks like the rotor is scraping against the brake caliper mounting bracket. Everything in th suspension appears tight. The only thing I can think of is that my bearings are going bad. Has anyone else experienced this?
Old 02-24-2013, 02:05 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,394 Likes on 747 Posts
It could be, you didn't say whether it was a front or rear rotor that was rubbing.
Old 02-24-2013, 02:12 PM
Charley Hoyt
It is the front left wheel.
Old 02-24-2013, 02:19 PM
Solofast
Solofast's Avatar
Take the caliper off and then the brake disk and inspect the hub and bearing. Could well be the hub is cracked and the only thing holding the thing on is the caliper.
Wouldn't be the first time.
Old 02-24-2013, 08:45 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,926 Likes on 5,332 Posts
Did you check the hub by rocking the wheel up and down with your hands at the 12 and 6 positions? Seems like something that is allowing that much rotor movement would also allow the complete assembly to rock up and down a lot.
Bill
Old 02-24-2013, 09:22 PM
Charley Hoyt
Bill
Yes, I tried rocking the wheel up and down but there wasn't an noticeable play. I assume that it takes more force than that to make it deflect. I haven't taken the rotor off yet.... But I will before I drive it.
Old 02-24-2013, 11:26 PM
moespeeds
moespeeds's Avatar
Check the hub bolts as well. Mine came loose and showed similar symptoms.
Old 02-24-2013, 11:45 PM
Charley Hoyt
Thanks, I will check them.
Old 02-25-2013, 12:36 AM
fatbillybob
fatbillybob's Avatar
Sounds like you are on the right track Charlie. Buy the SKF hubs and consider replacing the other 3. We breaks the stock hubs on track especially with sticky tires. This is a known issue. Van Steel and hardbar sell the hubs maybe pfadt too. Hardbar loves the nordlock and hex bolts but they really are not necessary. The hex bolts are a nice conversioon however makes it easier to trackside service and the T55 size iirc is not that hardy when you have some age and grime on those old bolts. A nice air tool makes your life a lot easier when you do this job and the cheapo harbor freight ball joint remover kit works great!
Old 02-25-2013, 07:32 AM
k24556
Support Corvetteforum!
k24556's Avatar
If the caliper bracket is contacting the rotor, then there should be some damage on the bracket as well, from any contact. I would expect to see a groove, though, not smearing. Were the pads bedded (broken in) properly?
From the apearance, it looks something like what i experienced, a ball of rubber got thrown there and smeared on the rotor. when it happened, my ABS went nuts on hard braking in a braking zone.
Old 02-25-2013, 09:19 AM
Charley Hoyt
Thanks for the advice Carl. It looks like some SKF's are the way to go. A couple of years ago I purchased a Kent Moore ball joint tool that works great. But why do the ball joints need to be removed to change the hubs? Is it a clearance issue?
Old 02-25-2013, 09:21 AM
Charley Hoyt
In the picture it looks like pad smearing but it appears to be metal to metal scraping.
Old 02-25-2013, 12:03 PM
froggy47
froggy47's Avatar
There is one ball joint fastener hiding behind the lower ball joint, basically impossible to get a wrench on without popping the ball joint. Ball joints = easy with the HF or KM tool.
I did a video, click below, on using the tool. Search YouTube channel.
Old 02-25-2013, 01:36 PM
moespeeds
moespeeds's Avatar
I second Froggy's video. Helped me through it when I did ARP long studs on all of mine. I safety wired my hub bolts, though it's overkill for sure. Red loctite won't hurt. If they are a problem coming out later (they won't be) just add a little heat. You basically can't check the lowest bolt once the hub is back on, so I wanted the peace of mind since mine came loose on track and I lost the brakes.
Old 02-25-2013, 05:50 PM
k24556
k24556's Avatar
If it is metal to metal what other piece of metal shows wear? that will give you a clue as to what is causing your problem. Usually metal to metal does not discolor, and you see fresh exposed and sometimes really rough gouges. All I'm suggesting is SKF hubs are $350 each and if the original isn't bad then replacing them won't cure your problem.
With the caliper off, that bearing should be as smooth as butter. The bearings get rough feeling long before the clearances open up. If the bearing is smooth and there is no visible wobble, look somewhere else. Did you put fresh brake fluid in before going, if not, maybe you boiled on one side and you now have air bubbles (on the other side so this one bites more for the same pressure. Also, if they are stock pads which I suspect they may be, you may have just overheated the pad material. That is what it more looks like vs bearing clearance.
I still think there may be some transient material, a rock or something like that that got inside and made that mess.
Old 02-25-2013, 06:31 PM
Charley Hoyt
The bearing didn't feel rough. I am going to take the bracket off to see if I can confirm if it is what is rubbing. The pads are Carbotech XP-10's. I put new fluid in right before taking it to the track...But I will bleed the brakes because my pedal got VERY soft while at the track...but, I am not sure how that could cause this. I also checked for material stuck in the pads and nothing is there. While driving I can hear metal to metal scraping when the brakes are applied fairly hard. I am also going to check to see if there are any issues with the Caliper bracket or the mounting bolts.
Old 02-25-2013, 07:41 PM
taken19
Track Junky
taken19's Avatar
What tires are you,running? With PS2's, I was on the verge of smearing XP-10's on stock Z51 calipers. As soon as I stepped up to Hoosiers, they were thoroughly melted onto the rotor. The pics look very similar to what I was experiencing while on PS2's. it could be that you are out-driving the XP-10's.
To Does this indicate a bearing problem?
Quick Reply: Does this indicate a bearing problem?
