Aim Solo DL and RaceRender2 Corvette C6 Dash Overlay
Just got the Aim Solo DL and pulled this together prior to my first track day with it. I like it a lot so far, but I am wondering if there is a way to log brake pedal or brake pressure. Also the steering wheel angle channel isn't logging anything useful.
Suggestions or improvements? Obviously the track map, lap times, best lap etc are not active because there is no start/finish line in this data set.
My DL is not picking up the steering angle either on my 05 but I also have a dtc pointing to a bad sensor. New one should be going in tomorrow, I'll let you know if it fixes anything.
A couple more refinements. If anyone wants the RaceRender template for this, let me know. Doesn't have to have to be used with an Aim Solo DL logger -- you can change the gauges to display whatever you are logging.
Next track day is VIR North Course on 7-Mar so I will post a link to a track video.
