Weight loss if going with Pfadt lightweight coilovers?
Old 03-05-2013, 09:47 PM
DansBlkonBlkZ06
DansBlkonBlkZ06's Avatar
Default Weight loss if going with Pfadt lightweight coilovers?
What is the weight loss by removing Z06 springs and shocks and replacing with Pfadt lightweight coilovers? I'm in NASA TT3 and don't want to shed too much weight.
Old 03-06-2013, 08:32 AM
mountainbiker2
mountainbiker2's Avatar
I lost around 7 lbs. total with LG.
Steve A.
Old 03-06-2013, 08:34 AM
el es tu
el es tu's Avatar
Originally Posted by blaine123
Suspension:7.5 lbs each front and 7.75 lbs each rear. GT2's are 7.70 lbs each front and 8.20 each rear.
OEM Shocks/Leaf Springs -------------> (35.5lbs)
OEM Shocks/Leaf Springs-------------->Pfadt Feather Weight Coil overs 6lbs per side 24lbs (-11.5lbs)
OEM Shocks/Leaf Springs-------------->LG G2 coil overs Fr: 7.5lbs each R: 7.75lbs each 30.5lbs (-4 lbs)
OEM Shocks/Leaf Springs-------------->LG GT2 coil overs Fr: 7.7lbs each R: 8.2 each 31.9lbs -3.6lbs
OEM Shocks/Leaf Springs--------------> Pfadt Coil Overs X 4 (32.5lbs) (-3lbs)
OEM Shocks/Leaf Springs-------------->Moton Coil Overs X 4 (36lbs) (+.5lbs)
OEM Front Sway Bar---------------->8.2lbs or 20.5 w/endlinks
OEM Front Sway Bar---------------->Pdadt Comp Sway Bar w/endlinks 21.9lbs (+1.4lbs)
OEM Rear Sway Bar----------------->11.8lbs
OEM Rear Sway Bar-----------------> Pfadt Rear Sway Bar ??
OEM Front/Rear Sway Bars-------->Pfadt Light Rate sway bars w/ links (18.8lbs) (-13.5lbs)
One of my favorite threads - Z06 OEM and Aftermarket Parts Weight List:
http://forums.corvetteforum.com/c6-z...ight-list.html
Old 03-06-2013, 12:21 PM
rithsleeper
rithsleeper's Avatar
I thnk we could all loose 8 lbs on a diet and it would save money on food cost.... ill expect a check in the mail for compensation for the money I just saved you.
Old 03-07-2013, 01:18 AM
johns68
johns68's Avatar
Can confirm the stock weight and LG weight in Blaine123's list ... just did this a few weeks ago, and weighed everything coming off and going on.
Old 03-09-2013, 09:36 AM
Z06Tracker
Z06Tracker's Avatar
Dan, I am pretty sure with the Ultralights, the difference was 11 lbs.
Old 03-09-2013, 02:33 PM
froggy47
froggy47's Avatar
Do you have a link?
I recall being in a discussion like this about some "XYZ" coil over and it turned out the CO weighed more, so a CAREFUL approach is warrented.
In other words don"t ASSUME every CO setup cuts weight. One of the Pfadt guys specifically made the point that weight (savings) is not the only or main reason to use CO.
Old 03-09-2013, 06:53 PM
el es tu
el es tu's Avatar
I think the eibach coilovers retain the stock springs(no idea why). This is probably the heaviest setup you can run...
To Weight loss if going with Pfadt lightweight coilovers?
Quick Reply: Weight loss if going with Pfadt lightweight coilovers?
