Help with oil pan
Old 03-07-2013, 10:33 AM
silverslashstreak
silverslashstreak's Avatar
Default Help with oil pan
I am putting a ls6 from 05 ctsv in our grand sport replica. I am totally new to the LS world and we use the car for auto cross Nd track days. I want to keep it a wet sump and the caddy pan is too deep for ground clearance.
What pan would you recommend?
Jeff
Old 03-07-2013, 11:07 AM
sperkins
sperkins's Avatar
2pc batwing pan would be fine. Even a 1pc batwing would suffice.
I used a 1pc pan with no problems for 3 years.
Old 03-07-2013, 11:43 AM
silverslashstreak
What brand pan do you use?
Old 03-07-2013, 12:04 PM
sperkins
sperkins's Avatar
GM.
You can pick them up pretty cheap here on the forum.
Old 03-08-2013, 12:26 PM
silverslashstreak
Thanks for the info, I am starting to get excited about this conversion.
Jeff
Old 03-11-2013, 09:56 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Not sure if this link will help but street and performance has done a lot of swaps and they have a lot of different info on this page. If you look at the drop down menu under LS2 they have various oil pan measurements - one link has GTO, F-body and Caddy - another has the C6 LS2 pan. Hope this helps.
http://www.hotrodlane.cc/New%20LS%20...ge.html#Lstech
To Help with oil pan
Quick Reply: Help with oil pan
